01-28-2005, 08:07 PM | #1 |
What tranny could it be??
I ran accross a trans for sale that has me baffled. It was assumed to be a SM 465. Not. The bellhousing says GM made in Mexico cast in. It came out of a 1 ton 70 model. There is a hump towards the rear drivers side and reverse gear is to the right and forward. The same side as 465 but opposite direction?????? Does anyone know what it is? It has a PTO cover on the passengers side and not the drivers.
Dave |
01-28-2005, 08:41 PM | #2 |
? here are a few to look at.... http://www.novak-adapt.com/knowledge...on_gateway.htm
01-28-2005, 11:57 PM | #3 |
Sounds like a backwards 420. Never heard of reverse in that direction in any trans
01-31-2005, 01:19 PM | #4 |
It is a wierd one! It has the sm465 length, but thats where it starts getting different. Only one PTO port on passengers side. Reverse shifting is on the same side as the 465 but forward engage instead of back.
Still researching. Dave |
02-02-2005, 01:14 PM | #5 |
ttt
02-02-2005, 02:09 PM | #6 |
Not trying to bust your you know whats but it sounds like the 420 but you maybe are looking at backwards or something? The way you describe it if what you call the rear of the tranny were actually the front then it would match a 420 exactly.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
02-02-2005, 05:48 PM | #7 |
Please read my post again. The 420 has the pto door on drivers side and hump on passengers side. I know that tranny like the back of my hand! I have one I adapted to a Jeep. I also have about 6 spare 420s!!!!
Dave |
02-02-2005, 05:50 PM | #8 |
Rear of vehicle.
02-02-2005, 06:27 PM | #9 |
NP435? They were used in two wheel drive GM trucks of this era. I have never owned one, and I don't know the shift pattern.
http://www.novak-adapt.com/knowledge/np435.htm
Tim |
02-02-2005, 07:15 PM | #10 |
user # 2756
Yep, NP435 responded on your other post. Should have an aluminum top.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
02-03-2005, 01:11 PM | #11 |
The Length Is 12, The Np235 Is 10 3/4. That Is Why The Guy Thinks It Is The 465.
02-03-2005, 04:17 PM | #12 |
user # 2756
The 465 has 2 pto covers. Do you have a picture? It is a 4spd? At least that's what everybody is assuming.
02-04-2005, 01:08 PM | #13 |
4 speed
