01-28-2005, 08:53 PM | #1 |
66front supension?'s
Hi to all current owners.Does someone have answers on this topic?? I got this project(66 shorty fleetside). I have already airred the back,and it gets super low.all is good! But the front, "as i was told" will not go very low without spindles. is this true?? I wanted to just cut springs for now to bring whole truck alittle lower.will this drop the front at all/or how much? "the person telling me this isn't really the best source". I need more knowledgable help. I am going to install air in front as soon as i can afford it. postscript:with rear air up the truck is even height now. i just want entire level to run lower...the whole air purpose right!! c-pics: truck aired up & half down.also rear with 18.5 mickeys & boxed in firewall.
01-28-2005, 09:06 PM | #2 |
you can cut the front springs,but you will have to be careful driving it.a bad dip in the road will cause the lower a frames to bottom out at the crossmember.mine are all beat up.also as the truck gets lower,the tire will get closer to the fender.i changed to drop spindles.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
