Garage Queen Material
is this my overheating problem???
i think i hopefully HOPEFULLY figured out why my truck is overheating...
i'm thinking its my radiator cap. if i squeeze the top hose it will push air and stuff into the reserve tank. if i squeeze it with my dads radiator cap on it, nothing will happen. |
#2 | |
Workaholic
Try driving it with the other cap? |
#3 | |
that very well could be it. it was the same way on my 4x4 when i bought it, the rubber seal that seals the cap to the radiator was almost completely gone. i don't have an overflow can it just goes on the ground but the system would just contiously overflow and not build pressure. the cooling system needs to be able to build a certain amount of pressure, this raises the boiling point of the coolant
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
well, at first the truck was running in the normal temp range, and then it started overheating again. and then it filled up my overflow tank...
#6 | |
