disk front brake prop valve help
ok all I have added disk brakes to the front of my 68. I have a prop valve off a 72. Does the larger (rearward) hole feed the front or the rear? I thought the front but wanted to make sure I am trying to get the brake lines run.
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Custer had a plan too.
According to my manual:
on half tons the front bowl of the master cyl. feeds the front hole of the valve which feeds the front disks. on 3/4 tons, the rear master bowl feeds the front of the valve which feeds the front disks. Does that make sense?
72 K15 GMC (aka Big White) Performance Rockers, Cab Corners, and Floors Fossil Fuel Glutton Neighborhood Nuisance 98 BMW 540i for Speed (Sold ![]() 05 Subaru Outback for mileage |
yes Joe it does. I didnt have a manual for a 72 . The front one is the smaller of the 2.
Thanks for the info. Dave
