The old longhorn is gettin a gear change
Yup, as much fun as those 4.10's are, they are coming out in favor of the original 3.40 gear that were in the 12 bolt. i have a new pinion yolk for 1350 U joints, & also plan to upgrade the drive shaft, & add a set of Moser axles......lookin for tha "freeway flyer"
sweet...did it originally have a big block?
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
No, it was originally a 350 powered truck.....it has run 2 455 Olds mills, & 1 425 cad , & a couple sb chevs over the last 20 yrs tho.... 69L
![]() Join Date: Mar 2003
In my experience big blocks really like the 3.5--3.4 ratios. My 68 GMC has a 3.54 ratio-factory. My 68 longhorn, I put a 14 bolt in with the 3.42 ratio. Both trucks are big blocks
Yes, a mid 3's gear is perfect for a BB! I am running a 383 sb, with a 6spd trans behind it.....hoping that little stroker has enough "grunt" to pull a little taller gear. @ 29" tire, on the 3.40 gear , with .76 overdrive.....should set me really easy on the cruise range(3000 would be 100 mph).....that should keep up with the deisels running across Illinois
