Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-30-2005, 12:22 AM   #1
454_72_4X4
454_72_4X4's Avatar
Any small truckers out there? V8 S-10 FOR SALE
FOR SALE;
87 S-10 shortbed standard cab truck as a roller
Already setup for a V8.
Specs as of today;
355 5 speed (won't go with the truck)
Custom 4 core radiator (made by Superior Radiator
for S-10 V8 conversion)
All motor mounts and custom double hump crossmember
Custom header/manifolds and true dual 2-1/2 inch
exhaust with turbo mufflers.
All front suspension was rebuilt a few years ago using
all poly bushings and all new parts, (everthing replaced
with new except the control arms and spindles)
New; tie rods, centerlink, idler arm, adjuster sleeves,
ball joints, wheel bearings, rotors, calipers, bushings.
Has an IROC Camaro steering sector.
Stock 3.08 rear with custom slapper bars.
Ford Probe bucket seats
Almost all grey interior, (red dash and seatbelts) Have a
grey dash that would go with it.
Needs some body work. Cab corners mostly and some small
dents, scratches, etc. I have cab corners for it.
Rear Blazer bumper
Front bumper has a recessed license plate and holes for
round fog/driving lights.
Parts that wouldn't go with the truck are;
Engine
Transmission
Clutch setup, (flywheel, clutch disc, pressure plate, slave, master
and line)
Tach
Steering wheel
Might work out a deal for extra $ for these parts;
Gauges
Stereo?
Tires/wheels (have others to make it mobile)
I'm thinkin about $750-$800? after I remove the above mentioned parts.
LMK what ya'll think.
Located in Northeast Missouri.
Here's a few older pics, (hasn't changed much);
I will get newer pics if anybody's interested.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-08-2005, 02:01 AM   #2
454_72_4X4
454_72_4X4's Avatar
TTT/\
Edited and officially for sale now!
Come and drive it if you're close!
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
