01-30-2005, 04:28 PM | #1 |
Cantankerous Geezer
Lower Radiator Hose Solution
I've been battling this for a week. 350 in stock location with a long water pump and 4 row radiator. Tried several hoses, finally decided to try Yukon Jack's solution of a 70664 plus a short 90 hose and a coupler. Went to put it together today.
Started by trimming one end of the 90* hoseput it on and did some measuring. Didn't know for certain how the 70664 hose was supposed to go in, but it looked like I would need to trim both ends. One end has a short leg with a moderate bend, I decided to put that end to the engine, and trimmed a few inches off the other end, and aligning the end with the short bend to the hose that was on the water pump. Was marking to cut both hoses, when I realized that I could remove the 90* hose and install the 70664 on the water pump. So, here it is, the 70664 installed with a few inches trimmed off the long end, and it clears the frame.
Fred There is no such thing as too much cam...just not enough engine. |
01-30-2005, 04:33 PM | #2 |
Cantankerous Geezer
One more thing. After I figured out how to put the hose on, I came in the house to get the camera and the KY jelly. The wife saw me and said: "I am not going to ask, and don't even want to know!"
01-30-2005, 04:35 PM | #3 | |
HAHHAHAHHA Been there. I had to go through the same thing on my 68.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-30-2005, 05:32 PM | #4 |
I need to do that, sooner or later im gonna wear a hole through that hose.
1971 gmc 3/4 ton, 350, t350 |
01-30-2005, 06:36 PM | #5 |
its all about the +6 inches
Jewlws found the right lower hose a year ago or so iirc.
01-30-2005, 08:21 PM | #6 |
67-72 Addict!
I just checked my old receipts and I also used part number #E70664. I believe I also had to trim a little.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
