01-30-2005, 05:01 PM | #1 |
lifter question
I developed a loud tick yesterday and pulled the valve cover today to find what I thought was a collapsed lifter. (rocker bolt was not loose)
To make a long story short, the lifter pumped up and now I can't get the rocker back on due to not being able to get the studs threads through the fulcrum so I can start the rocker bolt. Is the lifter going to stay pumped up or will it bleed back down. (1.5 roller rockers) Sorry, I'm kinda inexperienced with these things but usually get by ok. Thanks for any help.
86 C-10 SWB 2wd -355/TH350, 3:73's (Vin# says its a V6) Best ET: 13.0 @ 101mph (NA) 11.9 @ 108mph (100 shot) 02 Chevy 2500HD DMax (tow vehicle) 84 GMC Sierra 2500 00 Formula M6 hardtop |
01-30-2005, 05:26 PM | #2 |
Rotate the engine untill the lifter goes down then you will be able to reinstall rocker.
01-30-2005, 10:13 PM | #3 |
Thanks, I've got bigger problems it looks like. Ended up with a bent pushrod after reinstalling and cranking over.
01-30-2005, 10:19 PM | #4 |
7000 #'s of american IRON
that doesn't sound good.
01-30-2005, 10:45 PM | #5 |
Did someone say MUD?
Yeah I've been there befoe, good luck man...Later Mike
Im in the market guys...so keep ya eyes peeled -------------------- Mini trucks are for guys who cant get it up! |
01-30-2005, 10:55 PM | #6 |
Thanks guys, if it gets real bad, atleast I can fix that rear main seal I've been cussing about.
