GM ONLY BABY!!!
What is needed to install Camaro tach?
I really like the 70-81 Camaro tach conversion some of you guys have done. What kind of wiring do you guys use and how do you know where to hook it up to the Camaro tach? Is it a pretty easy install? Any info would be appreciated. Thanks!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
member #16
![]() Join Date: Dec 1999
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
GM ONLY BABY!!!
That looks easy enough. But how do I wire it up. I currently have an aftermarket tach, can I use the wires I have ran now, or does the Camaro tach have wires already attached to it? How do you wire up the clock, is there just a +pos. and -neg. wire to attach the clock? I might want to do that also. Thanks!!
GM ONLY BABY!!!
Has anyone changed the needle on the Camaro tach to match the 67-72 truck guages? Will it fit? How do I wire it? Thanks!!
