Old 01-30-2005, 08:47 PM   #1
Shev
Head Peon
Shev's Avatar
Simple notch?
I'm looking for some ideas for a simple notch for my '72, this one isn't going to lay frame. I looked at CP's notch, but I really don't feel like spending $149 for it. I want to be able to tow with it (dad is having his 1954 Chris Craft restored and wants to use my burb to tow it) so keeping the strength is a major concern. Anybody got pics or advice?
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 01-30-2005, 11:06 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
try *****************. He has a cheaper route im sure!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 01-31-2005, 12:10 AM   #3
Shev
Head Peon
Shev's Avatar
Yeah I'm gonna call him tomorrow...his usual answer to me is draw it and I'll make it for ya...LOL...guess it's time to do some measuring.
Old 01-31-2005, 12:20 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Make your own out of pipe and plate....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-31-2005, 12:31 AM   #5
lofly'a
lofly'a's Avatar
nice work N2TRUX, that's what i'm gonna do.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 01-31-2005, 02:55 AM   #6
roj2323
i would have to agree with the pipe and plate method. it looks 1000 times better than the bolt in kits, it should be stronger and the parts should be well under $50 at yor local hardware store or steel supply shop.
ondrew
p.s. don't bother with menards try home dept since they have a awsome selection of steel.
roj2323 is offline   Reply With Quote
Old 01-31-2005, 03:15 PM   #7
RIDDLA
RIDDLA's Avatar
how low does that sit N2TRUX ?
68 GMC-Stripshow
70 Chevy Monte Carlo
72 Chevy Monte Carlo LOLO
72 Chevy Suburban Blurban
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
03 Cadillac Escalade-Duecesix
84 Cadillac Coupe Deville DeElegance
B.O. A Lifestyle Money Cant Buy!
Win,Lose, or Tie
I'm a Raider till i die
RIDDLA is offline   Reply With Quote
Old 01-31-2005, 05:28 PM   #8
XXL
Seņor Member
XXL's Avatar
for the 67-72, you'll probably want to make your half-pipe a few inches long, then after you tack it in, grind off the excess. The frame is not "square" at the axle line... something the bolt-in notches account for.
XXL is offline   Reply With Quote
Old 01-31-2005, 07:06 PM   #9
SCOTI
SCOTI's Avatar
I used that bolt-in notch w/o any issues & towed my car trailer. After I started towing more often, I decided to go ahead & weld it in for xtra strength. My truck doesn't lay frame but is dropped between 7-8" in the back. If you have access to a welder, then the round pipe & plate method is cheaper. But, if you want to get it done @ home & don't have a welder, the bolt-in works fine. If done right, the pipe/plate would look better IMO.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-01-2005, 12:56 PM   #10
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
Pipe method is good. be sure to use thicker 1/4" pipe. My freind has the pipe method done, on his 66. I have the bolt in notch, not welded in. I've towed a bobcat with a heavy tilt back trailer, behind my blazer with no problems.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 02-02-2005, 04:33 PM   #11
bigbluthng
bigbluthng's Avatar
what diameter pipe did you all use? i was thinking of 3/16" pipe about 8" in diameter. would that be too big??
bigbluthng is offline   Reply With Quote
Old 02-02-2005, 06:46 PM   #12
orange72
orange72's Avatar
you generally want to go about 2 inches bigger in diamater than axle tubling. so with 3 inch axle diameter then 5 inch pipe would work good.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 11-01-2005, 06:33 PM   #13
geology rocks!
geology rocks!'s Avatar
Re: Simple notch?
Any more notched pics? Anyone have picks of a non-bagged notched setup?
geology rocks! is offline   Reply With Quote
Old 11-02-2005, 05:17 AM   #14
BigMike
BigMike's Avatar
Re: Simple notch?
Western Chassis has the half pipe weld in kit similar to the pics above but a tad smaller...Pleanty of room for the axle, but smaller. I bought them 2 weeks ago and will be installing them this weekend. I paid $39 for them. My Brother installed them in his and they look awesome, nice and clean looking.
Mike
BigMike is offline   Reply With Quote
Old 11-03-2005, 12:15 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Simple notch?
It sits this low....V
Articles-
"Refining Sierra"
Old 11-03-2005, 08:29 AM   #16
Bowtiefreak
Bowtiefreak's Avatar
Re: Simple notch?
I would like to use the pipe method shown above and was wondering what the proper location would be on a 67-72 truck seeing how you can't put it directly over the axle as described by XXL because its not square to the axle line.
I would be useing some 5 or 6" pipe.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 11-03-2005, 02:14 PM   #17
SCOTI
SCOTI's Avatar
Re: Simple notch?
Yes, you put it directly over the axle C/L. Once installed, the c-notches are parallel to the rear end housing.
For mine, I took the shocks off & the coils out so ther rear end could be raised until it hit the frame. Using a level, I marked the frame for both sides of the axle (front/back). I split that in half & regarded that as my axle C/L & scribed a line on the top, bottom, & outside of the framerail for easy visual reference.
I then measured & scribed the C/L of the c-notch itself, aligned the 2 scribe marks together, & traced the area that needed to be cut out.
The difference on yours will be the need to cut the width of the c-notch longer because the frame staggers vs. being straight. Once it's welded in, simply trim off the excess from both the inside/outside of the frame.
FWIW, if I would have followed the instructions that came w/my bolt-in c-notch kit, the notch would not have been centered because the instructions had you measure from a factory hole on the side of the frame when determining the C/L for the c-notch. My measurement indicated it would have been almost 1" off center.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-03-2005, 04:45 PM   #18
Bowtiefreak
Re: Simple notch?
Old 11-03-2005, 08:58 PM   #19
3100 special
Street Rod Dreamin'
3100 special's Avatar
Location: Work:Batam, Indonesia/ Home:League City, Texas
Re: Simple notch?
Mike
I can't seem to find their home page. Plenty of re-sellers but, I want to look through the main site. Anyone have any idea the parent company name?
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2007 GMC Sierra 4X4
"I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776
3100 special is offline   Reply With Quote
Old 11-06-2005, 12:58 AM   #20
valleycustom
Re: Simple notch?
Check out the C notch I made.
http://67-72chevytrucks.com/vboard/s...d.php?t=179176
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 11-07-2005, 01:07 AM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Simple notch?
Great work there. I noticed you added a plate over the frame for support. Why didn't you box the inside?
I'm not trying to start a big debate over right/wrong way to do it, just wanted your opinion....
Articles-
"Refining Sierra"
Old 11-07-2005, 01:24 AM   #22
love it loud
Calibration Engineer
love it loud's Avatar
Re: Simple notch?
is your frame boxed at the notch n2trux? it's hard to tell if it is or not in the pics, but I like how the outside of the frame rail looks stock without any extra plate. how was it done?
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 11-07-2005, 02:41 AM   #23
valleycustom
Re: Simple notch?
I'm going to but I'm leaving that for last. I just wanted to get the notch in so I can get the rear setup installed.
Later
Jr
Old 11-07-2005, 05:15 PM   #24
geology rocks!
Re: Simple notch?
Great link Valley, keep the pics coming!
