Old 01-30-2005, 09:35 PM   #1
Fred T
Cantankerous Geezer
Fred T's Avatar
Fan shroud mounting
It appears that some sort of spacer is needed on the fan shroud screws. I don't know for sure, since my truck was butchered in some areas by the P.O. This is on my 69, 350 w/ a/c. When I took it apart there wer 4 different size screws with nuts for spacers.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-30-2005, 10:35 PM   #2
Randy70C-10
Randy70C-10's Avatar
If there were nuts on it for spacers, it sounds like the wrong radiator support brackets are bolted on the radiator support. There shouldn't be any spacers.
Randy70C-10 is offline   Reply With Quote
Old 01-30-2005, 10:50 PM   #3
gonebad2
Merciless Butcher
gonebad2's Avatar
The bottom of the shroud is attached to the radiator support with clips. I'll post a pic of them if you want.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-30-2005, 11:02 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Please do. Thanks.
Fred
Old 01-30-2005, 11:15 PM   #5
gonebad2
Merciless Butcher
gonebad2's Avatar
clips
The originals were a little bigger. GM discontinued them and replaced them with these.
Old 01-30-2005, 11:41 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
I took some pictures, hopefully one of y'all can figure out what's not right. There's about a 3/8" gap between the shroud and the upper support. It's a 4 core radiator.
Fred
Old 01-31-2005, 12:02 AM   #7
gonebad2
Merciless Butcher
gonebad2's Avatar
I think you may need the longer retainers for a four core radiator. Those look like the shorter retainers ( for a three core ). They should sit flat on the radiator. Maybe the pic is just deceiving. Sorry I was'nt able to help.
Old 01-31-2005, 12:13 AM   #8
4x4Poet
That was my first thought, as well, gonebad2. I would follow gb2's advice and count the rad's cores. If you have a 4-core rad, then a previous owner must have installed the rad without also upgrading to 4-core supports. I'm concerned with what the rad's tank bottoms look like in their 3-core rubber cushions and metal rad supports.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-31-2005, 12:24 AM   #9
gonebad2
Merciless Butcher
gonebad2's Avatar
If you use the 3 core mounts with a 4 core radiator, you run the risk of vibration on metal to metal contact wearing a hole in your radiator.
Old 01-31-2005, 09:36 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
I found some problems by doing some measuring, old against new. The new radiator is 1/4" wider and taller. The new radiator cushions are 1/8" thicker than the old. Add that up, and there is an additional 1/2" of height. The ribs on the tank were against the core support at the top, took care of that by notching the flange on the core support. I haven't arrived at a solution to the height issue, yet. Need to do some clearance checks with the hood.
Also, the bottom edge of the fan shroud doesn't match up with the core support. Now, while I mutter some words about aftermarket parts.
Fred
Old 01-31-2005, 11:21 PM   #11
mr402
I'm no small block expert but that looks nothing like the shroud on my big block trucks. It does look a lot closer to a shroud for a later year truck. I can post pics tomorrow if needed.
mr402 is offline   Reply With Quote
Old 02-01-2005, 12:05 AM   #12
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The shroud clips on my truck look different, they're bigger and stick out more than the ones gonbad2 posted a pic of. Anyway here's a pic of a 4 core rad. hold down with the correct hex head screw for holding the top of the rad. shroud to it, not sure if it's gonna help you or not. Sorry about the pics, the webcam is all I have to work with right now. FYI these are about 6.5" long, you might wanna measure the ones on your truck and see if they're shorter or not.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 02-01-2005, 12:17 PM   #13
Fred T
Cantankerous Geezer
Fred T's Avatar
Thanks, Robert. Mine are 6.5" long.
Fred
Old 02-01-2005, 01:31 PM   #14
junkyardjohn
junkyardjohn's Avatar
FRED -- I WASN'T GOING TO REPLY TO YOUR THREAD, BECAUSE I WAS SURE SOMEONE WOULD COME UP WITH A SOLUTION. IT'S PRETTY SIMPLE. GO TO YOUR LOCAL BONE YARD & GET A FAN SHROUD OFF OF A 70s OR 80s CHEVY VAN. IT WILL BOLT RIGHT UP & LOOKS RIGHT. YOU CAN ALSO GET THE UPPER & LOWER MOUNTS FOR A 4 CORE RADIATOR & CLIPS TO HOLD IN THE BOTTOM OF THE SHROUD FROM A VAN TOO. (THEY ARE THE SAME AS TRUCKS) WHEN INSTALLING NEW RUBBER CUSHINS, THEY TEND TO BE A LITTLE TALLER AT FIRST, BUT AFTER A WHILE THE RUBBER MASHES DOWN. I LIKE TO JUST REPLACE THE BOTTOM ONES FIRST, & PUT IT TOGETHER WITH THE OLD TOP ONES. THEN AFTER THEY'VE BEEN IN THERE FOR ABOUT A MONTH, I PUT THE NEW TOP ONES IN. IF YOU HAVE TROUBLE FINDING THE CLIPS, P.M. ME & I'LL SEND YOU SOME. YA NEED TO GO TO THE BONEYARD, IT'S THEROPUDIC (SP?) JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-01-2005, 02:13 PM   #15
Fred T
Cantankerous Geezer
Fred T's Avatar
Thanks a bunch, John. Now I have to wait and hope the weekend weather is good. I was getting ready to start machining some fittings, but a trip to the boneyard is easier.
Fred
Old 02-01-2005, 10:41 PM   #16
No problem sir, glad I could help.
RJD
