01-30-2005, 09:40 PM | #1 |
Oilfield Trash
oil pan on a 86 6.2diesel
can you pull the oil pan off the engine with the engine mounts still connected in the truck
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
01-30-2005, 09:42 PM | #2 |
Oilfield Trash
that is a 4x4 truck
01-31-2005, 12:11 PM | #3 |
Ultimate Diesel Dude
I replied to your PM, Blue85, but I will also post here for future reference:
On 4WD trucks, there is plenty of clearance to drop the oil pan on the 6.2L diesel without doing anything else except dropping the starter and perhaps jacking the front end of the truck up off the axle a bit for extra clearance. On 2WD trucks, some folks have reported being able to drop the pan without lifting the engine, but I have found that I have to remove the motor mount bolts, jack up the engine a bit, and then slide the pan out. Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
01-31-2005, 02:19 PM | #4 |
Oilfield Trash
right on thax for the info i think i have a cracked piston thatis why i was wondering
01-31-2005, 03:19 PM | #5 |
ROCKET POWER!
I replaced the oil pan gasket, rear main seal and oil pump on my '90 K5 Blazer. I removed the turbine inspection cover and support beams, then unbolted the pan and turned the crank so the pan cleared the front counterweight and crank throws. It was not necessary to remove the starter or lift the engine. I had the truck on jackstands that were under the front axle, to allow more crawl space below the axle.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
