Attaching fender emblems?
I dont think I can reattach the fender emblems on my 68 with the fenders installed. How have you "attached" them Glue, epoxy douple sided tape or what.
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
The correct way would be to pull the inner fender wells out the get to the studs but you can use double sided tape.
![]() Join Date: Apr 2003
You can use a barrel clip. Maybe some of the venders carry them. If not check with your local auto paint and body store.
its all about the +6 inches
Personally, i've always used 3M emblim adhesive. Never had a problem yet.
NAPA carries barrel clips--have them on my fender badges.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
I will do some checking on the barrel clips. The inner fenders are out but there is just not quite enough room to get in there. I had left the inner fenders off because I thought there was more room but it is tight.
Thanks Dave
