Will brake line work as an airline?
I know, this may be a DUMB question, but, in the next few weeks, I'm going to bag the front of my truck, and I need to figure out what to use for airline. I'm just going to run it from the front bags, up to the firewall, where I'll have a schraeder valve for each side, to fill them.
Head Peon
![]() Join Date: Dec 1999
I guess it would work...or if you are looking for cheap and easy maybe 1/4" line would work for ya...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
BK Built
i suppose it would work... but if your just trying to stay cheap, i would say run some 1/4" lines, and just run a manual valve, with for say a 3 gallon tank(can hide it anywhere) which a schraeder valve on it instead of a compressor. its cheap, and easy.
ok, then, how does airline stay on the brass fittings? Do I have to buy special fittings to fit the airline? I'm doing it even cheaper than having a tank, I'm just gonna run the line up to the top of the firewall, on each side, and pop the hood to fill/empty the bags. This is just a temporary setup, until I have more money, to get rear bags, and valves and compressor/tank setup.
Under construction!
Why not install standard air line w/ brass compression or PTC fittings? I wouldn't spend the time to bend and secure hard line for a temporary setup.
2001 Silverado bagged on 22's. *Sold* |
#6 | |
www.73-87chevytrucks.com
Tim, find a tractor trailer repair/supply shop or a service/support operation. They should have the lines/fittings you need.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Under construction!
WORD to what Chris said. If you can't find a local supplier, order everything from www.*****************!
#9 | |
Under construction!
Compression fittings are exactly as they sound. Hard to describe over the internet but they are very simple/quick/easy to install. Push to connect fittings are even more simple and if brass, equally as reliable.
![]() Check out www.InnovativeAirSuspension.com too. ![]()
Señor Member
It's OK to be cheap, but don't skimp on something that's iffy if the air is holding your truck up. Busted line often = tow truck.
Head Peon
I buy all my fittings from www.hoseandfittings.com It's the cheapest place I've found, and it's all Parker fittings. Click on the "Group" tab, that will take you to the D.O.T. stuff (always buy D.O.T. approved fittings and hose for your bags...) You can't beat Suicidedoors price on airline though...
#13 |
Mike
Thanks shev.Less than a $1 a foot for 1/2" and in colors.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#14 |
Got L.E.D.s
Napa has all the stuff you'll need. I use barb fittings and 300 psi hose (the brass barb type fitting that have the plastic piece) . It's cheap, and it's never failed. Just go to Napa
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
#15 | |
Progress = 0%
Check out McMaster-Carr for air line and fittings. 1/2" air line for $0.72/ft., 3/8" air line for $0.55/ft. in all colors. Their brass D.O.T. fittings are also reasonably priced. Just a comparison..... a 3/8" NPT male straight fitting is $6.00 at ART..... $4.32 at McMaster-Carr. A 3/8" tee fitting at ART is $10....... $7 at McMaster. 40-feet of 3/8" air line from ART is $50..... $22 at McMaster. With the money you save, you could buy some ART t-shirts and decals and still be ahead of the game ![]()
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#16 | |
Señor Member
#17 |
Got L.E.D.s
Well they've been on my blazer for over a year. The important thing is they don't rub on anything. I run 1/2" valves and line. And have had the psi up to 170psi. If the hose was going to come off the barb fitting it'd done it by now, and if it's not going to come of the barb fitting and the hose is rated at 300psi I don't see the problem. I work with high pressure hose, all the time. If you where conserned about the hose coming off you could hose clamp them to. Mine is not. The hose is made for the fittings. I'll get part#s tomarrow.
McMaster-Carr is a good place to get stuff. I've ordered from them before.
#18 |
I have some 3/8" O.D. line I can sell ya ... how much do you need?
#19 |
belly dragger
Checkout www.fairviewfittings.com
#20 |
Shev,
Thanks for recommending HoseandFittings.com!! I got ALL my stuff, for $20 SHIPPED! (4 fittings, and 14' of 3/8" line) |
#21 |
Got L.E.D.s
![]() These are the fittings they are made to be used with FLEX-LOCâ„¢ 300 PUSH-ON Thermoid www.jgbhose.com
