01-31-2005, 05:38 PM | #1 |
72 AC truck with two inlets on tank sender
Can someone confirm the line routing for me on the two inlet tank sending unit?
On the two inlet sender units, I believe the smaller one is for the return line from the fuel pump. I cannot find any information on this setup and I would like to know if this is the correct routing. I have not been able to find a listing on the fuel pump for the trucks but I am sure the later cars have them. My 69 El Camino has the return line coming back off of the fuel filter and I have seen fuel pumps on the mid seventies Corvettes with the fuel pump that has the return line on it. Any help would be appreciated. Jim |
01-31-2005, 05:51 PM | #2 |
Mike
My 72 suburban and 72 blazer are set-up like that.You can get the fuel pump at autozone that has the return line.I don't know how good they are,I've not used one from there.They are listed under 72 c/10
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
01-31-2005, 08:42 PM | #3 |
Mike,
I had not thought about checking Autozone! The Autozone site says that my local store has one for $12.99 with limited life time warranty. Thanks for the information. Jim |
