01-31-2005, 10:21 PM | #1 |
help plz Brake Problem Help And E Brake ?
I"m having a problem with my brakes the pedal stays down when pressed I can pull it up by hand and its fine I just noticed my ebrake cable is broke were it comes out the inside of the frame rail could this cause the problem I'm having?
01-31-2005, 11:06 PM | #2 |
GM ONLY BABY!!!
Sounds like you have a leak somewhere. Either a brake line or wheel cylinder. Are the inside of any of your wheels wet with brake fluid? The e brake shouldn't have anything to do with the brakes working properly. Oh, and you probably need to purchase a new e brake cable. It is also a good idea to have the brake fluid flushed about every 5 years or so. In my opinion brakes are VERY, VERY, important.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
01-31-2005, 11:26 PM | #3 |
its all about the +6 inches
Even if the master cylinder was removed, the pedal should still swing back up. There is a spring up under the dash that ensures of it.
Most likely you are dealing with a bad vacume booster and need a new one. The Parking brake is unrelated. |
02-01-2005, 04:05 PM | #4 |
GM ONLY BABY!!!
Does the booster sound like it is groaning or making any kind of noise when you step on the brake pedal. Mine was in my 96 Z71, when the booster was going bad. I have towed too many trailers without electric trailer brake controller, that's why mine went out.
02-01-2005, 07:14 PM | #5 |
Franko72
Bad return spring? check for leaks , look at fluid level in master cylinder first.If low, check the system for leaks .Check the vaccuum line going to your brake booster.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
02-01-2005, 08:46 PM | #6 |
The pedal return spring is up under the dash in the pedal support bracket. Here is a pic without anything in the way since the bracket is out of the truck.
Jim |
02-01-2005, 11:38 PM | #7 |
its the booster did a little trouble shooting
unbolted mastercylinder problem remained unhooked booster from pedal assembly problem gone.pedal returned to normal going to replace both 90 bucks autozone should i get a 3/4 ton one. |
