Old 02-01-2005, 11:44 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
more holes
what would you suggest fixing these with? i took my cab lights off tonight and this is what's underneath. my truck looks 400 times better without those lights!
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-01-2005, 11:50 PM   #2
Randy70C-10
Randy70C-10's Avatar
You can fill them in with a mig welder.
Randy70C-10 is offline   Reply With Quote
Old 02-01-2005, 11:50 PM   #3
67ChevyC10Stepside
it wont warp the roof?
Old 02-02-2005, 12:12 AM   #4
sweet n rare67
Young truck fanatic
sweet n rare67's Avatar
if you take your time and keep the heat down it wont warp the roof.....one tack at a time.. best of luck
'67 Chevy Longstep 2wd 350 w/4spd manual Muncie M21. My first project.
**Proud to be Valley Trash**
sweet n rare67 is offline   Reply With Quote
Old 02-02-2005, 12:21 AM   #5
67ChevyC10Stepside
i dont have a welder so i will have to pay to have it done. i think i'm just gonna fill my trim holes with fusor.
Old 02-02-2005, 01:37 AM   #6
Crank
Crank's Avatar
Well it'd be nice to invest in a mig welder. Can get setup for 5-6 hundred. When filling holes, you can use a heat sink, such as copper or aluminum, just kinda bend to fit behind the piece being fixed, it'll distribute the heat evenly, therefore less warping, and also, mild steel wont stick to aluminum or copper, so you wont run the wire thru and keep opening up the hole or have a big gob of weld on the back of the panel to grind down.
Brandon
Crank is offline   Reply With Quote
Old 02-02-2005, 02:34 AM   #7
1969 GMC
1969 GMC's Avatar
how would you get a piece of copper or aluminum inside the roof? I have heard of the penny trick before, but those are some small holes.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-02-2005, 03:12 AM   #8
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I welded mine up with my MIG. No need to back it if you use the right technique. I made filler pieces from 18 gauge and cooled the welds with a wet rag. No problem! Come on over and I will do yours for free...no charge...nada! I know it is a bit of drive but what the hey!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 02-02-2005, 12:20 PM   #9
67ChevyC10Stepside
yeah thanks....i'll be right over in my truck that doesnt even drive yet! LOL :P
Old 02-02-2005, 12:47 PM   #10
69 Short Fleet
Holy Ghostbusters! Those lights look pretty funky, much better with them OFF your truck!!
69 Short Fleet is offline   Reply With Quote
Old 02-02-2005, 01:12 PM   #11
86SILVERADO
86SILVERADO's Avatar
If you cut a circular piece of sheet metal (use a hole saw without the center bit) that fits inside the hole in the cab roof you can use a strong magnet to hold the patch piece in while you get it tacked. Buy a mig welder it will be the best money you have ever spent. I don't blame you for taking those lights off They look like something out of a jetsons episode. You might consider the teardrop ones though unless you are just dead set on the smooth cab roof look. Here is a pic of mine on my cab. Just my opinion but they are the nicest style of running lights as far as I am concerned.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 02-02-2005, 09:16 PM   #12
stllookn
stllookn's Avatar
I just cut the patch pieces square and then rounded them with my sander. Hold them with a pair of pliers...it goes pretty quick. I use the magnet on the end of my scribe to hold them in place while I tack them. Good choice...hate the clearance lights on anything smaller than a 1 ton flatbed...LOL!
Old 02-03-2005, 12:54 AM   #13
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
I second 86 Silverado..............I think the running lights on my one ton are also the nicest.............Now I just need to work on the rest of the truck.............
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 02-03-2005, 07:56 AM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The roof has considerble crown to it right there. You'd have to try hard to warp the metal in that area. The curve gives it a lot of stability.
Old 02-03-2005, 12:11 PM   #15
Blue Beard
Blue Beard's Avatar
Except for the larger center hole they can be welded easy. Filler would be idea for the center hole.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
