Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 02-02-2005, 09:16 AM   #1
67mbsc
Needing Rh Exhaust Manifold
Needing a RH exhaust manifold for my Dually. 350 engine, the manifold runs down below the spark plugs, the dump sweeps back at the end of the manifold, and the "extension" is very long, equivalent to having a heat riser on it, I'd say. But it does NOT use a heat riser. I have a 4X4 dually, just like it, and it uses the same manifold as 4X2. Actually needing the same manifold for BOTH trucks! If you have one that you can sell me, please let me know. Many Thanks
67mbsc is offline   Reply With Quote
Old 02-02-2005, 01:27 PM   #2
99-2door
99-2door's Avatar
what year??
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 02-02-2005, 02:43 PM   #3
bigunde
Rusty Rockerfeller
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
bigunde is offline   Reply With Quote
Old 02-02-2005, 07:06 PM   #4
67mbsc
Ex Manifolds
Both trucks are 1989 but the bodies are the generation before that (73-87) because they are 1 ton duallies.
Old 02-02-2005, 07:10 PM   #5
67mbsc
Similar
They look ALMOST like the ebay link, but the exit dump is longer! The ones pictured, I have, and it was too short. Won't reach the exhaust pipe! It's almost like it needs a heat riser in between to be longer!
Old 02-03-2005, 08:49 PM   #6
bisquik65
bisquik65's Avatar
I have one off a 89 suburban 350 R/V old style....will that work??? It needs new studs put in,i can do that if it will work.. $45 shipped
bisquik65 is offline   Reply With Quote
Old 02-04-2005, 04:47 PM   #7
71monteme
71monteme's Avatar
check these guys out.ebay
i know the auction ended but give them a call and tell them what u need. just bought mine from them.
thanh.
71monteme is offline   Reply With Quote
Old 02-04-2005, 06:09 PM   #8
badone07
Project 2 Resume
badone07's Avatar
The set below came off an 87-88 Suburban. They had the 1 port per manifold emissions setup. I sealed them up by welding in a plug in each. I used them just to break in the motor in my 84 crew cab. They do have a heatriser though, with the flap removed. Do yours look like these?
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
