Old 02-02-2005, 02:49 PM   #1
1972
Majician
1972's Avatar
1/2 ton to 3/4 ton questions
I want to convert my 1/2 ton C10 to a 3/4 ton C20.
Will an Eaton (10 bolt?, it has the gears that come out the front and a bolt on rear cover w/ fill plug) swap in place of my 5 lug 1/2 ton axle? Is the u-bolt spacing in the control arms the same? Will my 1/2 ton panhard work with the eaton?
Will 3/4 ton ball joints work in my 1/2 ton a-arms or will I need 3/4 ton a-arms? Will '73 to '87 spindles work with my '72 1/2 ton control arms?
Would it be better to just sell the 1/2 ton and buy a 3/4 ton?
1972 is offline   Reply With Quote
Old 02-02-2005, 03:06 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Yes.. To do what you want you need to swap out the front suspension and the rear differential. And there are a lot of 3/4 tons out there that are begging for an owner.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-02-2005, 05:20 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Even if you use the 3/4 ton suspension your frame is still a half ton frame, not the beefed up frame that came with C20s or C30s. It's easier to just buy a C20 than convert to one. Yeah you could do it but it would take a lot of time and $$$, especially if you have to chase the parts around. Also if you swap out the spindles from a 73-87 3/4 ton it will give you a lift in the front, which is a good thing. I wanted to do that but I also wanted to keep the stock front suspension. Has anybody done this swap with newer front running gear? If so how's the ride?
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
