What do you guys think about welding in your crossmember?
So I was going through the new Street Trucks Mag....on the cover it has got a 67-68 Slammed Yellow Fleetside. The guy welded in his crossmember. i have been thinking of doing the same to my burban. It would make your front end stronger. I also plan on boxing my whole frame. What do you guys think about welding in the crossmember......pros vs cons!
I like bolts, they come apart much easier than weld.
69 GMC 2wd 350cid 82 Toyota 4wd, 3.8L V6, 6" lift, 35's, locked and loaded 76 Datsun F10 1.4L ***FOR SALE*** 04 Honda Shadow 750 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
This is just my opinion, but where you would have to weld it would be a pain, especially if your upper control arm studs ever got bent, you would have to cut it off, plus and I don't really see a benefit of it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Head Peon
They did like a 3 1/2" crossmember drop on that truck...could that be a reason they welded it in?
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
Well here is what I'm thinking....
#7 | |
Happy to be here
![]() Join Date: Mar 2000
I guess it all depends on what crossmember you are using.....
Correction, the Fatman Fabrications set up is bolt in (at least for the coil overs which is the stage III package). But I too am thinking about welding it in just because I probably will be locating it in a different position also.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
Happy to be here
I guess it depends on what you want the end result to look like. It can be bolted in and would allow you to remove it later if needed. If your going with a Fatman IFS I assume your going for appearence as well as function. I say weld it in and clean up those frame rails. Just remember measure twice, weld once....
I was not even going to measure.....i was going to eye ball it! j/k
I plan on boxing the whole frame and then welding it in. I know what needs to be done. |
#12 | |
Happy to be here
#13 |
Stage V fatman bolts in as well. I modified mine by moving it forward 1.400" to better center the wheel in the wheel well. Im using the 2" drop spindles in conjuntion with the shockwaves. I had to assemble and diassemble everything multiple times. Did alot of measuring and drilling to move all the mounting points evenly. Fabricated 3/16" plate to the same dimensions as the side flanges of the fatman crossmember, welded them to the flanges to fill the gap. then bolted it back on. The frame width gets narrower as you go forward. I like the idea of being able to repostion or go back to stock if I wanted.
Mark 72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction 05' GMC Sierra Denali LQ9 |
