Old 02-02-2005, 10:26 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
wtf mate?
i went out and tried to put my driveshaft in tonight and it will only go part way in. it goes probably almost exactly halfway and stops? wth?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-02-2005, 10:30 PM   #2
roj2323
do you have a long or short yoke on the driveshaft? are there any burrs/ rust inside the yoke?
ondrew
roj2323 is offline   Reply With Quote
Old 02-02-2005, 10:34 PM   #3
67ChevyC10Stepside
i dont know length wise...it was a 3 speed manual truck before. i was told it will be a direct fit to the TH350. i cleaned it out with a little wire brush before installing. i was told there is a bushing in the tail shaft and i might have to sand the driveshaft yoke a little? is that true?
Old 02-02-2005, 10:36 PM   #4
gmc67swb
gmc67swb's Avatar
Make sure the splines are not twisted on the output shaft of the tranny or the yoke. The slip yoke should be able to go all the way into the tranny.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 02-02-2005, 10:38 PM   #5
67ChevyC10Stepside
it goes really easy almost exactly half way...then stops. if they were twisted it would twist at the end right?
Old 02-02-2005, 11:14 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Stick it in there till it bottoms and mark it with a Sharpie, then remove it and stick your finger into the yoke and see if it's bottomed out at that depth.
If there is any rust on the yoke, you may as well remove the tailhousing and change the seal now before you puke fluid onto the ground. Trying to put in the rusty yoke will have damaged the seal. Yokes are to be polished smooth and rust free with emery cloth or crocus cloth.
Old 02-02-2005, 11:30 PM   #7
67ChevyC10Stepside
i took pics...yellow is where it goes...red is where it should go it looks like.
Old 02-02-2005, 11:31 PM   #8
67ChevyC10Stepside
more
Old 02-02-2005, 11:31 PM   #9
67ChevyC10Stepside
they look straight to me...
Old 02-02-2005, 11:35 PM   #10
Tx Firefighter
Something is wrong. It should go on to the red line. The yoke looks good in the pics.
Old 02-02-2005, 11:37 PM   #11
67ChevyC10Stepside
hence why i am puzzled....is that bushing thing true? should i sand it like i was told?
Old 02-02-2005, 11:38 PM   #12
Tx Firefighter
If it's a used bushing, it should definitely be loose enough to work. I've never had to do anything to the bushing to make the yoke fit, ever.
Old 02-03-2005, 02:27 AM   #13
67ChevyC10Stepside
they said sand the yoke a little.
Old 02-03-2005, 03:02 AM   #14
ZOOMY
burr
There must be a burr on one of the splines. If you still have the 3 speed, try reinserting the shaft into it. If it goes all the way, then the burr is on the tranny output shaft. Take the tailcone off & run your finger nail up & down all of the splines on both sides & all the way to the bottom of the grooves. The other possibility is that the output shaft is twisted near the center of the splined area.
ZOOMY is offline   Reply With Quote
