02-02-2005, 10:45 PM | #1 |
C Notching the frame
do u have to C-notch the frame on a 72 GMC sierra (1/2 ton) if u wanna lower it 4/6....i was talking to a guy today and he said he had no choice but to to it to his (2002) pickup because he kept bottoming out
please let me know, cause i wasnt planning on cutting my frame, i did it once to a 98' S-10 (c notched the frame and did an airbag setup with a 4-link...it was a pain thanks again Kevin |
02-02-2005, 10:47 PM | #2 |
If it's a coil spring truck, no, you don't.
The later model trucks like your buddy'd do need a notch for a 6 inch rear drop though.
79 AMC Pacer- straight six 85 Toyota Mini Truck- needs Viagra I'm also president of Mullet Men of America |
02-02-2005, 10:49 PM | #3 |
ive got the coils in the front, but ive got leafs in teh rear. (early classics sells the 4" lowering leaf spring setup and then the 2" shakle.....also will i also need a shock relocater kit aswell?
02-02-2005, 11:10 PM | #4 |
Watch out for your cornhole !
Definitely call ECE and ask them. Those guys will steer you straight. They get the Tx Firefighter Stamp of Approval (TFFSOA, TM, patent pending).
02-03-2005, 12:14 AM | #5 |
Don't use a 2" drop shackle if you have a wood floor. That would be a huge pain. It will hit the wood floor. ECE sell's a 1.5 " shackle that's what you will need.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-03-2005, 02:50 AM | #6 |
Here's mine and a pic of the notch I have. Maybe this will give you an idea.
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
02-04-2005, 12:22 AM | #7 |
thanks everyone...i dont have a wood bed (nor do i plan on getting one...so that shouldnt be a problem). so for a final answer, if i get teh 4"lowering leaf springs and the 1.5" lowering shackels....will i need to notch the frame? (cause i really dont want to, nor will i) and i need to know if i can lower it 4/6 with out any problems
Thanks Again Kevin |
