pics of shaved cowl
I finally got the cowl filled and put back on here's some pics. What do you think? I left the area behind scoop open for air. The after pics look a little weird because it rained this evening and the truck was wet.
![]() ![]() ![]() Last edited by modifiedGMC; 02-02-2005 at 11:55 PM. |
Never Done?
![]() Join Date: May 2000
That's pretty cool
User #12137
![]() Join Date: Apr 2004
hey that looks good and the heater will still work
![]() what kinda hood is that ? |
It's the stock hood with a custom built steel scoop I built. It wasn't an easy job but it didn't cost anything either which saved me about $400+ dollars. Besides it was fun doing.
Looks good. Why didnt you shave the antenna while you were at it?
#6 | |
#7 | |
That is an awesome idea. ![]()
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
does the heater still work, i wanted to shave mine ecxecpt that i need heater/defroster being in pac nw
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
Did you fill it mounted on the truck? If not was there any warpage of the cowl from the heat?
Thanks, Saulgoode |
#10 | |
Hey,
How bout some good pics of the hood as well and some details on how you fabbed it??? Thanks Stacey |
#12 | |
#13 |
Here's the pics of the scoop. some are when I first put it on and a couple are after primer.
#14 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looks Great I Just Did The Same Mod To Mine But Welded It All Closed..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#15 | |
