Old 02-03-2005, 04:01 AM   #1
modmach1
modmach1's Avatar
Belltech springs
I got some belltech lowering springs of my girlfriends 88 GMC Sierra, (Lill on the forum btw) That car is bagged now, so i wonder if they goes on my 80s truck? And how much can i cut away from them ?
My truck is lower in the back now (Belltech 4" drop) I just want the "cowboy" look for a few months before the flipkit, 3" drop spindles etc is here
The truck is missing one round of spring on the originals now..
Cowboy look= lower in front than back
http://www.moldestuket.com
1971 Mustang Mach-1 429 CJ-R
1973 Mustang Mach-1 289
1975/71 Pontiac Firebird Formula 400
1978 Chevrolet C-10 Fleetside Longbed Scottsdale
1980 Pontiac Phoenix
modmach1 is offline   Reply With Quote
Old 02-03-2005, 08:11 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The springs are different.
The 88 and newer style of trucks has straight wound springs.
The 63-87 trucks have a taper on the last coil of the spring.
You have to have the tapered end to locate it correctly in the upper mounts.
Old 02-03-2005, 08:17 AM   #3
Tx Firefighter
Notice the first spring has the same diamter top to bottom.
The second spring has a tapered section on one end.
That's the difference between the two.
Old 02-03-2005, 05:16 PM   #4
modmach1
modmach1's Avatar
Doh!!!
Thank you very much TX !!!
Do you know how much i can cut the original springs?
They are shaved one round now..
We use to cut 3 rounds on mustangs..
Old 02-03-2005, 05:21 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I don't recommend going over 1 coil on the trucks. If you want more drop, go with spindles.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
