Old 02-03-2005, 08:00 AM   #1
MDATXXX
Lowering???????
I have a 82swb i want to put 22's on it, my question to the board is what would be a good lowering height to lower my truck on the 22's i really want that low look but enough height to go over speed bumps and make turns, I heard 3/5 5/5 4/6 what do u think? What is a good price for lowering kit install?? Also i live in austin,tx do any one know of a place around here that will put a lowering kit on??? thx alot
MDATXXX is offline   Reply With Quote
Old 02-03-2005, 10:49 AM   #2
Ric83
Ric83's Avatar
to the board from another here from A town!!!
You know, before you asked, I never really thought about any shops here in town. Unfortunatly, now that I do think about it, I don't know of any. None
that I would even think of recomending anyway.
My cousin just lowered his a couple of months ago, but he and I did it at his house.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 02-03-2005, 11:16 AM   #3
C-10volvo
C-10volvo's Avatar
it doesnt matter how big your wheel is as long as you keep the same OD of the tire. i wouldnt recomend more than a 8.5 inch wide rim up front though. i would go with a 3/5 drop.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 02-03-2005, 12:16 PM   #4
gdev_
It depends on tire size and wheel width/offset. If you really want to go with 22's on all four corners, 3/5 would probably be the MOST you would want to go, and it would have to be with a realtively short tire. One thing to keep in mind when going to a 22 is that your tire selection becomes more of a factor, you have MANY more options sticking with 20's, and less headaches as well (especially in the front).
HTH,
gdev_
www.hillshotrods.com
gdev_ is offline   Reply With Quote
Old 02-03-2005, 01:31 PM   #5
MDATXXX
I Have 295-30-22 Tires
Old 02-03-2005, 02:34 PM   #6
C-10volvo
C-10volvo's Avatar
you cannot run thoes in the front
Ken Morgan
Old 02-03-2005, 03:06 PM   #7
75stepside
*Proud Member*
75stepside's Avatar
Originally Posted by TIMSPEED
OK guys, since a LOT of people ask the question "How low should I go with my C10" and "Where do I get the best parts for the best prices?" I thought that I would post a list of the best quality components, at the best prices, including tech tips to installing them. Then, other members will post their ride with certain drops to let everyone see how they look on a C10 (Such as a 2/4, 3/5, 4/6, 5/7)
||It's all from SummitRacing.com||
Front:
-3" DJM Drop Spindles (Part #DJM-DS2045H-3 for 1?" Brake Rotors, Part #DJM-DS2045L-3 for 1") $219 or $259
-2" Summit Drop Springs (Same thing as Bell Tech's just different color; Part #SUM-G727) $87
-Doetsch Tech Nitro Slammer Shocks (Part #DOE-4052G) $44 each (Need two)
Rear:
-5" DJM Flip Kit (Part #DJM-FK1024-5) $89
-2" Summit Shackles (Same thing as Bell Tech's just different name; Part #SUM-G756) $46
-Doetsch Tech Nitro Slammer Shocks (Part #DOE-4095G) $36 each (Need two)
Also, you will need to order This C-Notch ($45)
Why did you list these parts, and not others?
From all of the data/information I have collected, this is the cheapest route to go, as well as it's the route you'd want to go if you want to get maximum ride quality out of your lowered Chevy.
What if I just want to go with the 3/5 drop now, then a 5/7 later or even just stay with the 3/5?
That's the beauty of these parts...If you wish to start out with a 3/5 drop, you can and it will use the shocks listed. Then, if you want to add the 2" Drop Springs/Shackles later, you just add them and you're set.
Will my 3" Rub on my factory 15" rims?
Yes with the 3" Drop Spindle, if you are still running your factory 15" wheels, you will need to grind a little off of the top of the A-arm, so it doesn't rub, nothing too hard though. (Although if you're running 16's or bigger, you won't have any problems)
Will I have to get a notch to clear the 5" flip kit?
No, for the 5" Flip Kit, the only thing you must do is remove the factory bumpstock/bracket, which is very straightforward and easy. You only need to install the notch if you're going with the 7" rear drop.
What size tires can I run with the 3/5 drop, how about the 5/7?
With a 3/5 Drop, it will allow you to run the factory size 29" overdall diameter tire. With the 5/7 drop, the maximum overall diameter tire you will be able to run is 27".
What if I have long tube headers, how low can I go?
If you happen to have Long Tube Headers (Hedmann, Hooker, Dynomax, or similar) you can safely run the 3/5 drop and not worry. However, once you go with the 5/7, long tube headers will MOST LIKELY scrape, although I do believe there's a select few companies that make long tube headers that will clear a 5/7 drop (I believe Thorley's and possibly Sanderson's)
75stepside is offline   Reply With Quote
Old 02-03-2005, 06:05 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Sure you can. With my little friend here you can run 35 mudders and a body drop....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-03-2005, 07:39 PM   #9
C-10volvo
C-10volvo's Avatar
no no no. remove the front clip and bed, then you have yourself a mudder laying rocker on 44's. you might have to trim the fire wall a bit
Ken Morgan
Old 02-03-2005, 07:44 PM   #10
ocbaud
Garage Queen Material
ocbaud is offline   Reply With Quote
Old 02-04-2005, 01:53 AM   #11
MDATXXX
THX ALOT FELLAS do anyone have any pics with 3/5 or 5/7 drop on 22's
Old 02-04-2005, 02:01 AM   #12
C-10volvo
C-10volvo's Avatar
i don tthink anyone here is on 22's. well, there is one but he is stock
Ken Morgan
Old 02-04-2005, 04:32 AM   #13
r0lf-
Hotwheels?
r0lf-'s Avatar
22's up front are gonna be a PITA. I mean, more power to ya for doing it, but sheesh... Lemmie dig up a pic of one of Hills hot rods thats bagged on 22's, his ride height is almost higher than stock, seriously.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 02-04-2005, 04:33 AM   #14
r0lf-
Hotwheels?
r0lf-'s Avatar
Old 02-04-2005, 04:37 AM   #15
r0lf-
Hotwheels?
r0lf-'s Avatar
Thats gonna be about the max height your gonna be able to go down on 22's, I think that truck is on 20's, but you get the idea. Its not very low.
