Old 02-03-2005, 11:53 AM   #1
N242MUCH
what? to powder coat.
Can you guys tell me what all under the truck i should powder coat. I know the frame but what have you guys coated besides the frame. and after you were done what did you look back on and say i wish i would have done that part too. 69 3/4 ton 4x4 long bed. This will help me to get all the parts together at one time to the blaster and coater. One job is cheaper than shoot i need this part coated too. so with your input i can be almost 90% sure that it is one job and done. thanks scott
N242MUCH is offline   Reply With Quote
Old 02-03-2005, 02:06 PM   #2
incoma
incoma's Avatar
I had everything that bolts to the frame and is under the body coated + my radiator support and inner fenders. I also had the triangle shaped fender brackets and upper radiator supports done.
incoma is offline   Reply With Quote
Old 02-03-2005, 08:10 PM   #3
roj2323
i'm going to have my trans case done as well as the listed above but other than that i can't think of anything.
roj2323 is offline   Reply With Quote
Old 02-03-2005, 09:34 PM   #4
Vince M
Vince M's Avatar
Only your budget is going to limit you. If I had my way I would do everything. On my 68 I've done everything that bolts or attaches to the frame and then some. I paiinted the frame though. If there is any doubt that you will need to drill a hole or cut into the frame don't powdercoat it.
On my 4x4 I did my transfercase. I couldn't get paint to stick to it for very long. The powder sure stands up well.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 02-03-2005, 11:20 PM   #5
N242MUCH
as of now the money is not a problem the wife said i could have the income tax for the truck The guy doing the powder coating said the frame would be 500.00 to coat does that sound like a good price. He also said that i should think about all the parts that i want to coat. I don't have any idea on what can or can't be coated that is why i am picking the boards brain to get a list . so thank you incoma / roj2323 / vince M / for your help it's guys like you that make this a great board .I just hope that i can help you guys out some day and again thank you. if anybody else knows of any parts i can coat please tell me and remember i am new at this frame up thing so tell me or pic are better. scott
Old 02-04-2005, 05:29 AM   #6
BUXMAN66
go bucks!
rear panhard bar, frt. stabilizer bar,upper&lower control arms,trailing arms,hood hinges,hood latch,hood latch spear,bumper brackets, heck you can go on and on......lower shock mounts,battery tray,windshield wiper solution bottle holder.....use your imagination.that's what makes this a fun hobby.. goot luck!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 02-04-2005, 03:27 PM   #7
N242MUCH
buxman66 slow down i can't write that fast lol . with what you said i am adding to my list. See this is how it works . I now have more things to coat thanks to the board members. without you guys 1/2 of my list would not have been coated. thanks again scott
