Old 02-03-2005, 03:08 PM   #1
Lobo'74
Lobo'74's Avatar
Windshield washer wiring
OK . . . the original wiper motor and washer pump are bolted together under the dash. From the 1967 chassis service manual, page 12-27, there are 5 electrical spades on this assy. One pair together, and one section of 3 with 2 of them close together and one about 1/2" away.
The wiring diagram shows the two together has a double connector running to it, with one yellow and one dark blue wire. From the photo in the chassis manual this looks like the section that is the washer pump.
The 3 connecter block has one double and one single connector. The double has a dark blue jumper from the other double, and a light blue wire. The single has a black wire.
The original wiper/washer switch on the dash has three wires, the black, the dark blue, and the light blue.
The yellow wire goes to the fuse panel
I have an '89 integral washer bottle and pump that I want to wire to the original switch. Connect its red lead to power, grey lead to ground and it squirts a strong stream of fluid out.
I figure the black lead to be a ground.
I think the yellow lead is the power lead.
I have no idea what the dark blue jumper connection is for. Is it for the intermittent pulse of fluid so you don't get a continuous stream of fluid when the wiper/washer knob is pushed in? The chassis manual (pg 12-25) says:
"The pumping mechanism is actuated by a four lobe cam and driven directly by the wiper motor. Thus, when the wiper is operated, this rotor is always turning with the gear. Programming is accomplished electrically and mechanically by a relay assembly and ratchet wheel arrangement"
For the '89 pump (one red lead and one grey lead) I need the correct wire from the original switch (black, dark blue, light blue) to jump to the red, positive lead. I will ground the grey lead in the engine compartment.
SO . . . the question is, since the yellow (power) lead does not run through the wiper/washer switch, I am wondering if I need to use the dark blue jumper as the power source, or the light blue? Which one will operate electrically through the above mentioned "relay assembly and ratchet wheel arrangement" to give me a squirt? My guess is dark blue . . .
I KNOW that some of you out there have the right answer for this.
I'd do some time under the dash with jumpers to find an answer but is snowing and Truck is in the driveway . . . Wifes car is in the half of the garage that is presently open.
Thanks for any help.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 02-03-2005, 04:24 PM   #2
Lobo'74
Lobo'74's Avatar
Oops! I read the wiring diagram wrong . . .
5 leads going in.
Block of 2 that appears to be on the washer assy. Dark blue in and yellow in. Other end of yellow is fuse block. Other end of dark blue is wiper/washer switch.
Block of 3, split into a block of 2 and 1. The two has a jumper from other yellow and light blue. Other end of lightt blue is wiper/washer switch. The one is black. Other end of black is wiper/washer switch.
When I jump the '89 pump to the yellow on the block of two, or on the jumper going from there to the 2 on the block of 3, it runs full speed, non-stop without pushing in the washer switch on the dash.
When I jumper the '89 pump to the black or to the lt blue it runs at a reduced speed, non-stop, without pushing in the washer switch.
When I jumper the '89 pump to the dark blue it does nothing, even after the washer switch is pushed.
All connections made to the terminals on the '67 wiper motor/pump assy.
I want to be able to have the '89 pump squirt when I push in the '67 wiper/washer knob. I'm stummped.
"Truck"
'67 small window
Old 02-03-2005, 05:37 PM   #3
john
member #16
john's Avatar
Your wiper sw. is a ground switch. I think all you have to do is run ignition hot to pump and ground through the wiper sw. Pump will pump as long as you hold the switch. IIRC thats how I did the last one. Good luck John
john is offline   Reply With Quote
Old 02-03-2005, 06:51 PM   #4
Lobo'74
Lobo'74's Avatar
I'll try that. Power to the pump, ground through the switch. Now the question is . . . which one of the three switch wires to use. Black, light blue, or dark blue?
Anyone have any ideas?
Thanks again.
"Truck"
'67 small window
Old 02-03-2005, 08:34 PM   #5
JimKshortstep4x4
Smile
Dark blue and black are you slow and fast wiper speeds. The light blue is the wire that goes to your washer and the washer button grounds it.
As John said, the pump will continue to run as long as you hold the button down.
Jim
Old 02-03-2005, 08:51 PM   #6
Lobo'74
Lobo'74's Avatar
OK. I think I've got it. I run a hot lead to the pump positive lead and then run the "ground" lead on the pump to the light blue electric contact on the washer/wiper switch.
Right?
Thanks.
"Truck"
'67 small window
