Old 02-03-2005, 05:19 PM   #1
john j
booster with disc's
If i use disc's in the front and rear,do i need a booster? This is on my 58 long bed. johnj
you laugh at me cause i'm different ;
i laugh at you cause you're the same
john j is offline   Reply With Quote
Old 02-03-2005, 06:40 PM   #2
roj2323
realisticly YES
why? well it's safer, you don,t need to have a huge leg to push it, it will shorten your stopping distance by quite a bit and disk brakes really weren't designed for non boosted systems.
side questions
-are you conserned about the look of the booster, cost or something else? i'm currently trying to figure out how i want to boost mine so i'm looking for ideas as well.
-what rear disk brake setup are you using?
ondrew
roj2323 is offline   Reply With Quote
Old 02-03-2005, 07:02 PM   #3
john j
I have a chance to pick up a rear end that has discs on it. It's out of a camaro or firebird. They say a 71 to 80 fits pretty good. The cost is more than drum so to equal it out i was going to do away with the booster. If i use the booster i will just get the drum rear end. johnj
