Old 02-03-2005, 06:46 PM   #1
bigarmzz
bigarmzz's Avatar
converting deisel truck to gas
what all is involved in this???
i located a 82 or 83 4x4 short bed truck in good condition, but it was a deisel, and now the motor is out (blown head gasket or something like that)
i know i'll have to drain the tanks (dual tanks), and maybe change the filler neck, but what else?
what all will i need to do to convert it to gas?...
by the way, it supposedly has a 700r4
i'm getting it without a motor...incase ya hadnt figured out that one
-bigarmzz-
bigarmzz is offline   Reply With Quote
Old 02-04-2005, 01:09 PM   #2
60-66 Nut
Professional Beer Tester
If it's '82 or newer then it would be the 6.2 diesel, which should not be a bad swap. '81 was the last year they put the 5.7 Olds diesel in the trucks, but I don't think they put them in the 4x4 trucks anyway.The 6.2 trans will bolt right up to any Chevy V8, just use the flywheel for the gas engine. The motor mounts should also bolt up. Exaust, of course would have to be hooked up. Some of the 6.2 diesels used an electric fuel pump, but I'm not sure which years had it. That may need to be removed, if it has one. The filler necks should be fine. The power wire for the inection pump should hook up to an HEI distributor. Oil and temp sender units from the 6.2 should work, but there might be some adapting required to fit them on some gas engines. Simply abandon the glow plug system completely. The diesel radiator should be big enough for even a big block gas. The diesel probably has hydro-boost brakes, just use the diesel PS pump with the gas ps brackets. I'm sure I forgot something but I think that's the biggest part of it anyway. Hope that helps, best of luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 02-04-2005, 09:00 PM   #3
bigarmzz
bigarmzz's Avatar
wow, thanks man...very informative
so did they actually put a 700r4 behind a diesel?...i didnt think chevy did that...i thought all automatic diesels had a big buffed up 400 turbo
-bigarmzz-
Old 02-04-2005, 10:26 PM   #4
kevinr1970
My '86 1/2 ton 4x4 has O/D as did the '83 I looked at not so long ago.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-05-2005, 12:33 AM   #5
magnethead
7000 #'s of american IRON
magnethead's Avatar
4L80E? There aren't mnay OD's out therer that were made at the time to handle diesel torque.
magnethead is offline   Reply With Quote
Old 02-06-2005, 02:53 AM   #6
kevinr1970
I'm pretty sure mine is a 700r4. I not sure but I thought the 4l80e started in '88 with the change in the body?
I always wondered if the diesel 700r4's were a better built tranny because of that, but from what I'm told, its the same except TC and the solenoid(sp).
2000 Tahoe Limited
Old 02-06-2005, 10:18 PM   #7
Fatblock82
Just a note,the tourque convertor also needs to be changed,as a gas convertor has a higher lockup point.The P/S takes a bit of ingenuity,as the hydroboost takes a different bracket than regular p/s.My suggestion would be to find the whole setup in a gas truck.Yes,they did put 700r4 trans behind those diesals.Their not to stout,but then again,neither was the 6.2.
Fatblock82 is offline   Reply With Quote
Old 02-06-2005, 10:24 PM   #8
TrainD5115
North Coast, baby!
TrainD5115's Avatar
The US Army had a boatload of 6.2l diesel engines with OD trannys. They are out there.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 02-07-2005, 12:31 PM   #9
arveetek
Ultimate Diesel Dude
arveetek's Avatar
Yep, the 700R4 was introduced in 1982 the same time as the 6.2L diesel. Nearly all, if not all, 1/2 ton automatic diesel pickups, Blazers, and Suburbans, whether 2WD or 4WD, came with the 700R4. Nearly all 3/4 ton and 1 auto diesel pickups and Suburbans came with the TH400. The SM465 manual was offered in either the 1/2 ton or 3/4 ton, 2WD or 4WD. Some early 6.2L diesel 1/2 tons also had the NP833 4 speed manual with overdrive, but they're kind of rare.
In 1991, I believe, the 4L80E was introduced behind the diesel. Then the NV4500 came out as the manual option.
The TH350 was never offered behind the 6.2L from the factory. However, a lot of 350 and 400 trannies have been swapped in over the years to replace a failed 700. A lot of the early 700's, as you well know, were not that great and failed often.
So, basically, the light duty trucks had the 700, and the heavy duty trucks had the 400.
My suggestion? Put a diesel back in that truck and enjoy the benefit of hight torque and great fuel economy!
Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
