02-04-2005, 01:05 PM | #1 |
newly minted old timer
factory aux fule tank picts
For those of you have not seen what the factory aux tank look like. Here you go.
Notice how the carriage bolts go thru the tank? This is the first time I have EVER seen these bolts not rusted, or I should say welded to the tank.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
02-04-2005, 01:13 PM | #2 |
71 bb longhorn
When I took mine off it took quite a while even using a grinder to get them off. the tanks look in great shape.
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. |
02-04-2005, 01:30 PM | #3 |
Hey mtdave, 2?'s. Do you know where I can find one of the nuts for these bolts. Have you seen any for sale on here. For some odd reason I'm missing one. Also, what tool do you use to take these off. Tried to use the end of ratchet extension but was a hair to big for the hole.
Thanks, Scott |
02-04-2005, 02:08 PM | #4 | |
Mine came off by grinding the heads of the bolts off. Then I used an 8 pound sledge hammer to whack the remains of the bolt out. Then I cleaned/blasted/rammed the rust/dirt/crud out of the holes. For new bolts I bought a short 1/2" carriage bolt and a long piece of 1/2" threaded rod. I measured what I needed then welded two bolts together that long. For the nuts on the bottom I simply used a big washer, then a lock washer, then a nut. It has been that way for a couple of years now.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
