Old 02-04-2005, 08:00 PM   #1
ssls6
up and down slop in front CV joint.
How much up & down slop should be in the front CV joint on a 72 K5? I don't feel any torsional slop only up and down type motion. If I rotate it by hand, the slop runs up the side and then falls down. This repeats every rotation.
Thanks,
Richard
ssls6 is offline   Reply With Quote
Old 02-04-2005, 09:30 PM   #2
ssls6
Thanks. I went and checked it again and the ujoints or the center ball is out. The guy I bought it from must have filled them with grease when I picked it up.
My CV joint attaches to the TF case with 4 bolts into a flange. The H member says Spicer. Do I have a Saginaw or a Spicer CV shaft?
Regards,
Richard
Old 02-05-2005, 01:29 AM   #3
ssls6
If the pin is broke, do I need a new front driveshaft?
Thanks,
Richard
