Old 02-04-2005, 08:34 PM   #1
C10 - C90 Bill
C10 - C90 Bill's Avatar
'72 Manual Steering Interchange?
I'm trying to find out the complete interchange on a Manual Steering Box for a '72 C-10. I have a Hollander, but it stops at '72. (Need to get a newer one)! I believe the power steering interchange and the manual interchange are different. Any info would be appreciated.
C10 - C90 Bill is offline   Reply With Quote
Old 02-04-2005, 08:49 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
On my 71,
I changed mine from manual to power, pulled a unit from a 73 with its pitman arm, it bolts right in place and I use a new 73 pitman arm, no problems so far,,,,,I think you can use 71-78 steering gears, dont quote me on the years, but there is a change between 69-70-71. I also put a pump from the same year as my engine (67) so it looks factory and its fine, you will have to make your return line or pull one from a yard, pressure line i use either a 71 or 73 line,,,,, thats the best thing ive done for the 71 SWB ........Hope this helps...Also pull the piece from the steering column, you may need it, I cant remember. Another thing if you go from manual to power you might (dont have too) want to have your camber set for power steering, there is a difference, If i recall power units have negative camber and manuals have positive....... If i spelled wrong i blame it on my cold.......
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 02-05-2005, 08:58 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
My Hollanders has these listed for manual boxes:
70-78 Blazer/Jimmy
79-82 Blazer/Jimmy
67-78 Chevy/GMC Truck
79-87 Chevy/GMC Truck
(all of the above are 2 wheel drive)
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
