Old 02-05-2005, 01:22 AM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Talking Who makes H4 conversion for GMC trucks?
I am wanting to upgrade my headlights on my 72 GMC truck, they are 5 3/4" headlights. 4 of them. I also have a 66 Chevelle, which has the exact same 4 headlights. Anyone have any info? Thanks!!
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-05-2005, 01:40 AM   #2
StingRay
StingRay's Avatar
Bosch still makes em.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 02-05-2005, 01:43 AM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
HELLA makes a conversion so you can put a PIAA head light bulb in there
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-05-2005, 03:49 AM   #4
4x4Poet
I'm not sure of your terminology. AFAIK, Hella's 5-3/4" H4 headlights are simply replacement headlights comprised of unsealed, halogen lens assys with H4 bulbs. Once the bulbs are installed in the lens assys, one installs them like any other headlights. No conversion necessary. Or did you just mean upgrading to H4s? In any case, you can buy 67-72 GMC 4-headlight size H4s in a set of four thru Hella.
I already checked with my local auto accessories retailer who can obtain H4s for my '71 GMC burb directly from Hella's USA division (IIRC, in Florida). Expensive, but I won't drive a truck without great headlights at night in rural, unlit Montana. The deer seem to jump out of nowwhere with 67-72 oem quality sealed beams (GE, Sylvania, etc). And I will add a headlight relay harness to give the H4s direct voltage from the alternator. Mad Electrical is my preferred source for that.
BTW, for 67-72s, I've heard Cibie headlights are better than Hellas. More expensive also.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-05-2005, 11:40 AM   #5
ChevyDude
I bought the H4 Headlight kit for both my Chevy's : 72' K-10 and 71' C-10 from Rick's and they are a huge improvement. Kit was like $40 each but well worth it. Glass housings with the H4 bulb snapping into place and replaceable when it burns out. The headlights now throw a bright bluish white light instead of the old yellowee glow.
Don't see why you couldn't buy two kits and install this on a 4 light front GMC.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 02-05-2005, 11:54 AM   #6
2low72
I was thinking about doing the same with mine!
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 02-05-2005, 12:20 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Those European E-Code lamps are a fanatastic improvement. Years ago I put a set of 5 3/4" Cibies in my '66 Corvette - sadly, long gone now....
Anyway, if you can find 'em, get a pair of high/low H4 lamps, and a pair of High beam only. Can't recall which bulbs they used H1, H2, etc) but they have different lenses & reflectors designed just for high beam. The longer, narrower beam pattern works great in conjunction with the H4s on high. Worst thing about them is there's so much light on high that switching to low seems nearly like turning off the lights....
EDIT: Guys, I just Googled for a few minutes... Cheapest I found Cibies was $55 each at Talbotco.com... Hellas at $170 for a set of four (two H4 hi/lows, two H1 highs) at Rallylights.com... not cheap by any means, but certainly high quality lamps. I would strongly advise against Z-beams or City lamps...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-05-2005, 01:48 PM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Chevydude, I have seen the conversion for you Chevy guys all over. But us GMC guys have 4 smaller headlights (5 3/4"). You have 2 7" Headlights. Thanks for the info 4x4poet!!
Old 02-05-2005, 04:50 PM   #9
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
the chevy and gmc ones are different.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-05-2005, 05:17 PM   #10
68w/sbc406
68w/sbc406's Avatar
a chevy needs 2 7 inch H4 conversions and 2 H4 bulbs
a GMC needs 2 5 3/4 H4 and 2 5 3/4 H1 conversions
Old 02-05-2005, 05:23 PM   #11
muddpile
muddpile's Avatar
So for my 72 chevy, who would everyone say makes the best kit. My headlights I have right now project about 100 feet in front of me. Not good. I would like to upgrade to the whitish-blue headlights, but who makes a nice affordable kit, where could I buy it and what's the item #?
muddpile is offline   Reply With Quote
Old 02-05-2005, 05:38 PM   #12
67ChevyC10Stepside
ricks pickup parts...look at the catalog on his site.....
Old 02-05-2005, 06:59 PM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Beware the blue bulbs - they pass the blue part of the spectrum and block much of the rest - thus eliminating much of the usable light your eyes can see. Result = lousy night vision. 'Course, I had to find out for myself , and they were high-dollar bulbs too.
Seriously, if anyone wants to actually cut through the hype and learn something about lighting, one place to start is http://www.danielsternlighting.com/. Doubt if I'd buy from him (too expensive), but he knows his stuff.
- Mike -
RIP El Jay
Old 02-05-2005, 07:57 PM   #14
724wdcopper
graphic designer
724wdcopper's Avatar
i run the hella setup in my 72 chev. LOVE IT! best thing ever. had some cibies (aux) on my old 74 gmc jimmy. my dad put them on there when it was new, and they were impressive. if i had to do it over, i would look at cibies, but for the money hella is prety good.
just a side note, i run 100/55 watt bulbs. most of the ones they sell are 60/55. going to the 100 watt highbeams is a nice improvement. and yes, they are legal
724wdcopper is offline   Reply With Quote
Old 02-05-2005, 08:01 PM   #15
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I've always used the old sealed beam bulbs. I even have two NOS AC Delco ones I was gonna use but I think I'm going with the H4 conversion too!
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 02-05-2005, 08:31 PM   #16
ChevyDude
Sorry about that...I didn't know that....I stand corrected!
Alex
Old 02-06-2005, 03:27 AM   #17
4x4Poet
Stocker and 68w/sbc406 have it precise. The high beam lens assys come with different bulbs (H1) since they don't need the low beam filament. My mistake forgetting that feature. Thanks guys.
Just to be clear, Hella's true H4 lens assy kits come with Europeon style lens glass cuts–no doubt the E-code Stocker mentioned. I have them on my TravelAll (7"). So it's not just the H4 bulbs. Each lens has "H4" molded into the glass in the center of the lens.
Like near near all such headlights sold in Europe, the H4 bulbs cut off the beam (low or high) abruptly or sharply at approximately hood level out to infinity. But to the right of the pass headlight(s), the lenses direct the beam to rise up at approximately a 30º angle. This illuminates signs along the righthand roadside. Great on dark roads, especially. The sharp cut-off enables the H4s to be very bright yet not blind oncoming traffic (or clue the cops in that you have non-DOT-approved lamps.) I have never had anyone hit their brights when I'm on low-beam since the H4s never shine above their hoods. (OK, except maybe ricers.)
Edit: I looked at Cibie lamps on Talbotco.com and at Hellas on RallyLights.com. Thought someone would like the links. Thanks again, Stocker.
Old 02-06-2005, 01:24 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up
4x4Poet, thanks for providing the links (that I failed to!). I've been using E-codes in various vehicles since the early Seventies. The difference in illumination between them and cheaper alternatives is impressive. Personally, I've never felt the need to exceed the standard 55/60 watt bulbs, and I avoid cheaper bulbs also.
- Mike -
RIP El Jay
Old 02-06-2005, 03:45 PM   #19
68w/sbc406
68w/sbc406's Avatar
for the longest time i had the PIAA super white 80/80s but they stoped making them in an H4 so now i have to run 60/55s. the super whites (i think they are called star bright now) look like they would be blue when they are off, but when you turn them on they are just white. i like them better than the extreams which have a blue to the light when turned on.
P.S. how cool would those yellow Cibie head lamps look in the high beam spot of the GMCs
Old 02-07-2005, 09:27 PM   #20
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Aha!! I found them. I will be purchasing 2 sets of these. 1 set for the 66 Chevelle and 1 set for the 72 GMC. So how much do these overload the stock wiring and fuses?
http://www.carolinaclassictrucks.com..._Code=cct-lite
Old 02-07-2005, 09:40 PM   #21
67ChevyC10Stepside
that's like 180 bucks in lights....lol
Old 02-07-2005, 09:45 PM   #22
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
That's the cheapest place I have been able to find them. Plus, they are a member of the board, here.
Old 02-08-2005, 12:52 AM   #23
Warrens69GMC
Warrens69GMC's Avatar
.02,
http://cgi.ebay.com/ebaymotors/ws/eB...952062933&rd=1
40.00 plus the ride for 2 w/bulbs. 99.7+ feedback on 11,000 replies.
warrens69gmc
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 02-08-2005, 02:34 AM   #24
4x4Poet
Interesting option, Warrens69GMC. They don't have European lenses, but they do seem like a quality DOT-legal H4 set up. I'd expect the same or better brightness with a slightly less precise or useful lens refraction. Just a guess. I have less faith in DOT headlight lenses. I don't have first hand knowledge of those exact bulbs. The wattage is definitely high.
Old 02-08-2005, 04:25 PM   #25
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Thanks, Warrens69GMC, I will consider those as well.
