04-08-2002, 07:43 PM | #1 |
Light wiring for gauges?
I have added Autometer tach, volts, and oil pressure gauges in a tri holder on the bottom of my dash. I would like to hook up the light bulbs for night driving, so I can keep an eye on things.
What wire can I tap into. The bulbs in the stock dash are fed by a printed circuit , so I don't think I can find a place to splice into there. I don't have a light on my cigarette lighter either. What have some of you done to hook up accessory gauge lighting?
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
04-08-2002, 07:59 PM | #2 |
You can tap directly to the panel light fuse, in your fuse box. they will dim and brighten as the dash lights do when you turn the headlight knob.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
04-08-2002, 08:04 PM | #3 |
71Chev - Can you help me with a bit better description. Where on the fuse panel is the plug for the panel lights? My fuse panel has most of the white lettering wiped off of it. Not real good with wiring , in case you could'nt tell
04-08-2002, 08:07 PM | #4 |
top right vertical fuse, it did say PNL
04-09-2002, 01:35 AM | #5 |
Look for the plugin nearest the shortest fuse.
------------------ Just as if I knew what I was doin'
Just as if I knew what I was doin' |
04-09-2002, 10:16 AM | #6 |
If you have a tilt style column in your
truck, there 'should' be a grey wire coming from the fusebox...it goes to the light in the column to light the P R N D L2 L1 bezel Just tap into that wire for your new gage back lights..., just make sure your gauge housings are connected to a ground to make it all work ------------------ 71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73 See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
04-09-2002, 12:43 PM | #7 |
You can also use the gray wire that feeds the bulb or bulbs on your heater control or
heater ac control, which ever you have. If you tie into that wire your lights will dim with the dimmer. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
