Old 02-05-2005, 09:54 AM   #1
Tully
Hub size difference?
I have a 72 chevy K 20 with 8 hole rims and a 4 1/2" center hole. I also have K 20 chassis (un sure of year) under a 71 GMC body it has 8 hole rims with a 4 3/4" center hole. Why the difference? The chevy has a corperate rear axle and the gmc a dana, but the front hubs are different too. Could this be clue to what year my chassis is? I know this is the place to ask to get it strait, the knowledge on this board is incredible.
Tully is offline   Reply With Quote
Old 02-05-2005, 12:45 PM   #2
ryanroo
ryanroo's Avatar
i think the hole size could just be the wheels if the chassis is a 70-72 it should have the same hubs as long as it has an original big hub type dana 44. i know some aftermarket wheel are sold with bigger hub openings because ford truck require them, so maybe they are ford rims or aftermarket universal.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-05-2005, 02:06 PM   #3
Tully
I guess I was confusing in my question, am not asking about the wheels, I know I have several different brands of wheels. The hubs on the trucks are different, they are both Dana 44 fronts to my knowledge. I don't know the different part names of the brake drum-hub assembly but the spindle cone where the locking hub attaches is different diameter on the trucks also, much larger on the 72, but that's not where the wheels seat , where the wheels seat on the drum-hub is what is 1/4" different on the two trucks, and that is my question, sorry for the confusion.
Old 02-05-2005, 08:16 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The only thing I can think of is one is an internal style hub and the other the older external style hub. Are the dana44s both open knuckle?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-06-2005, 01:52 AM   #5
4x4Poet
I was thinking the same thing, Jim. Or a different type bolt on hub assy from a later year axle. Tully, you need to tell us how the manual locking hubs attach to their respective wheel bearing hubs. Bolts (allen head), internal splines, or studs with nuts, cone washers, lock tabs, etc.? Pics would be best if you have a digicam.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-06-2005, 09:31 AM   #6
Tully
Yes they are both open knuckle danas. The fronts are both disc, if you knocked the rotors off the 72 the hub comes strait out 4 1/2" diameter then the lock outs are bolted on with large allen bolts. On the other one with the rotor off, where the rim seats it's 4 3/4" then it tapers down to the locking hub with small allen bolts. The rear drum/ hub asbly are the same, 72 is 4 1/2" the other 4 3/4" where the rims seat. The only difference in the drive train I can tell is the corperate (eaton) rear in the 72 and the dana in the other.
Old 02-06-2005, 10:25 AM   #7
Bob Chayer
The 3/4 ton axle has larger wheel bearings than the 1/2 ton and the locking hub is externaly mounted. The 3/4 ton axle is also wider buy a couple inches or so than the 1/2 ton. The 3/4 ton is 8 lug. All the rest is the same. At least this is the way it is on my '71 3/4 ton Suburban and my '72 1/2 ton pickup.
Bob Chayer
71 3/4 ton 4X4 Suburban
Bob Chayer is offline   Reply With Quote
Old 02-06-2005, 05:51 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Bob, he has 2 different generation dana 44s, 3/4 ton. The one with large allen heads is the external style hub and the smaller one is an internal style hub.
Old 02-09-2005, 12:54 PM   #9
Truckstuff
Truckstuff's Avatar
Here is a older (-- to 75) 3/4Ton Dana 44 External Hub. This one uses the larger center hole rim.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 02-10-2005, 10:51 PM   #10
Tully
That's the exact hub thats on my 72 and 4 1/2" center hole rims fit on them. My other chassis has the internal bolt on hubs and they take a 4 3/4" rim. What's up with this? is it a clue to the age of this chassis? I was thinking 71 or 72 because of the disk brakes.
