Old 02-05-2005, 11:55 AM   #1
69 air cab
vibration problem
I have a 84 chevy that I just installed a new 350 engine (replaced the 305), rebuilt tranny, and rebuilt driveshaft. When I get to about 45 MPG I feel a slight vibration that feels more drive train than tires. I had an expert drive it and he did not feel what I did. He inspected the drive shaft and found everything ok. My tires are new but I think I will take it back for re-balancing.
Anyone experianced something like this? Any suggestions?
69 air cab is offline   Reply With Quote
Old 02-05-2005, 12:20 PM   #2
Trimman
Trimman's Avatar
I had the same problem. Is it a long bed? If so it has a long driveshaft that at speed will flex and get out of balance. I had a 2 peice driveshaft made for mine. Thats the only thing that will fix that. I had 2.71 gears at the time so my vibration was at 55mph.
82 C-10 Scottsdale LB owned since 89
350 crate vortec heads Crane 1.6 full rollers
edelbrock 1406
edelbrock performer eps intake
dynomax headers/flowmaster 70's
BTO 700r4 level 3
custom 2 piece driveshaft
12 bolt gov loc w/3.08
Trimman is offline   Reply With Quote
Old 02-05-2005, 01:20 PM   #3
69 air cab
Actually it is a short bed.
Old 02-05-2005, 11:21 PM   #4
Marty 57
Just because their new tires doesn't mean they are perfect
Marty 57 is offline   Reply With Quote
Old 02-06-2005, 01:54 PM   #5
r0lf-
Hotwheels?
r0lf-'s Avatar
Well, take everyones advice and check the Flywheel, Tires, and even pinion.
Mine vibrates a little because of the angle since I lowered it so severely. All these things come into play. Im not too sure how much damage it will do other than drive you nuts.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 02-06-2005, 03:06 PM   #6
Destructo
Check your front wheel bearings too, I was getting irritated with a bad vibe in my 85 Shortbed K10 and my front wheel bearing on the passenger side was loose, apparently I didn't install the lock ring right and it backed off.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 02-07-2005, 10:45 AM   #7
KShortell
KShortell's Avatar
I'll second that. See here for how I solved a similar vibration: http://www.geocities.com/kevinshorte.../Flxplate.html
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
