02-05-2005, 08:18 PM | #1 |
student wrench turner
Bump stop removal
is it ok to remove the bumpstop on a daily driver like in the picture. it will have a 2 1/2" drop spindle and 1 1/2" drop spring.
1969 Chevy C-10 with 250 L6 2002 GMC Sierra 2500 HD Duramax with banks six gun |
02-05-2005, 08:28 PM | #2 |
Not really, steel on steel and if you bottom out it can tear the suspension up, it would let it go past designed limits. You can trim them down if you need more clearance.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
02-05-2005, 08:30 PM | #3 |
Watch out for your cornhole !
I always remove the rubber and leave the steel base part on the arm. It gives the spindle steering stop a place to hit when turned to the lock.
02-05-2005, 10:57 PM | #4 |
User #12137
i cut mine off flat with the arm and then drilled a hole in the a arm and bolted Energy Suspension bump stops in there place !!!! the Progressive Suspension ones are 1/2 inch higher than the steel mount itself with the rubber part not on it !! seams to work fine so far , they have been on there since last spring or so
02-05-2005, 11:29 PM | #5 |
The LuvShack Garage
I DID BASICALLY THE SAME THING AS ROB EXCEPT I BOUGHT 1/2"
TOYOTA ENERGY SUSPENSION BUMP STOPS, THEY'RE THREADED ON ONE END, SLIP IT THROUGHT THE OVAL HOLE THE RUBBER 1'S CAME OUT OF AND TIGHTENEND THEM UP GAVE ME A EXTRA 3" OF TRAVEL, I THINK I USED A COUPLE OF LARGE WASHERS ALSO
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-06-2005, 01:43 AM | #6 |
i guess i will have to find a different set of arms or cut the brackets off another and weld them on
