Old 02-05-2005, 10:13 PM   #1
Purs
Got Big Block?
Purs's Avatar
Dyno Results
OK, I know the plug wires look tacky but I didn't have my wire seperaters with me.... Even so, I had a pretty good day at the dyno. The mill is a pump gas, solid flat tappet, oval port 496. Made 10 pulls. Best numbers were:
586HP @ 5700
600TQ @ 4600
I would've REALLY liked to get that magic 600HP number, but it was raining off and on so the air here wasn't that great... It had over 500 ft/.lbs of torque all the way from 3000 to 6000 RPM's.
I'm pleased with the results for what it'll be used for.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 02-05-2005, 10:36 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
WOW
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-05-2005, 11:16 PM   #3
Staceydude
Staceydude's Avatar
Very nice Purs,
Did you build the motor or did someone in DFW area build it?
If so who? If not who did you trust with the machine work?
Stacey
Staceydude is offline   Reply With Quote
Old 02-06-2005, 12:28 AM   #4
ROBBY WHITE
ZOIE AND ZACK
ROBBY WHITE's Avatar
SWEET WHERE DID YOU DYNO AT MAN THATS ALOT OF MOTOR
AMERICAN BULLDOGS AND CHEVY TRUCKS
71 1/2 SUBURBAN 402BB IN PROGRESS
90 1/2 TON SILVERADO
02 1/2 SUBURBAN
67 GMC 1/2 TON LONGBED
05 AVALANCHE
ROBBY WHITE is offline   Reply With Quote
Old 02-06-2005, 01:45 AM   #5
Purs
Got Big Block?
Purs's Avatar
sorry guys for posting this in the wrong forum, I'm a little tired from up all night with kiddo's then up early and at the dyno most of the day....
Can one of you mod's move it? thanks!
Old 02-06-2005, 02:57 AM   #6
Jeremy_5
Truck addict
Jeremy_5's Avatar
Brit, your done with your 496 already? Thats awesome!! Your alot quicker than I am.
Do you have any videos of it running?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 02-06-2005, 10:00 AM   #7
Purs
Got Big Block?
Purs's Avatar
Thanks Jeremy, I'm working on getting the videos posted, maybe by this afternoon.
Old 02-06-2005, 02:06 PM   #8
browndawg71
tell us more about this contraption. like cam duration @ 050, and what does the rotating assembly consist of. what are you using for carb. great #s , and i hope you have slicks on whatever your putting that thing in. BIG SLICKS.
every man must believe in something, i believe ill have another beer!
browndawg71 is offline   Reply With Quote
Old 02-06-2005, 03:59 PM   #9
Purs
Got Big Block?
Purs's Avatar
454 4 bolt block bored .060 over
4.25 Stroke Eagle 4340 forged crank, H beam rods, J/E forged pistons with a 5cc dome (all internally balanced)
Isky Z-55 Solid Flat Tappet Cam .590/.590 lift 254@.050 duration
Isky EDM lifters
Moroso 6 qt. oil pan
Rollmaster double roller timing chain
Professional Products SFI approved balancer
Oval Port 781 heads with 2.25/1.90 valves with MANY hours (not mine) of port work.
Edelbrock Performer RPM intake
Barry Grant 850 Speed Demon (custom worked)
MSD 6AL with GM HEI (no vacuum advance)
haven't bought headers yet, but will have 3" exhaust.
can't think of anything else.
Old 02-06-2005, 04:32 PM   #10
Big Bad 1972 Blazer
Big Bad 1972 Blazer's Avatar
Purs...sweet set up. You're numbers are good to see because I'm finishing up a 496 block built in almost the same manner. The only differance is that I'm running a set of Keith Black pistons with a .135 dome (9.5:1 w/ a set of 049 casting heads), a Comp Xtreme energy cam with .555 of lift, and a 770cfm Holley Truck Avenger carb. I gave up a little high end for throttle response & mid range performance, so I probably won't hit your bogey...but with some good air and a few other tweeks up the sleeve, who knows. I'm finishing up my block in a week or so and am having it dyno'd at the shop right after it's done. I'll post my results to see how they compare with your set up.
Big Bad 1972 Blazer is offline   Reply With Quote
Old 02-06-2005, 04:36 PM   #11
FirstGen
Just Don't Stop!
FirstGen's Avatar
Sounds like it is begging for some nitrous
Great numbers. Are you planning on running a TH-400? Should expect 480 horse 500 ft-pds. to the wheels, maybe more or less depending on the converter you pick! Then slap you a little 200 shot on that beast!!!
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 02-06-2005, 05:01 PM   #12
Purs
Got Big Block?
Purs's Avatar
Good luck Big Bad Blazer, let us know when you get the results.
FirstGen, you're right. My builder said that these mild pump gas motors LOVE a little N20.... with this all forged bottom end he said he wouldn't think twice about anything under a 200 shot.... I've got the Cheater kit in the garage right now but am planning on waiting for awhile. When I get tired of it at this power level I'll hook it all up.
As far as the tranny, right now I've got a TH350 but don't expect it to live long behind this TQ. I'm keeping my eye out for a good TH400 core or even a 4L80E...
Old 02-06-2005, 09:12 PM   #13
browndawg71
i run a 350 behind my 468 and have really been suprised how it held up. mine dynoed at 480 at the wheels on the motor. ive heard a th-350 dont have as much drag either. you combination is a good one , that thing is going to be a tire frier. dont cheap out on the convertor cause your gonna need a good one with that torque.
Old 02-06-2005, 09:22 PM   #14
FirstGen
Just Don't Stop!
FirstGen's Avatar
A th-350 will hold up for a while without good traction. After a few good launches, kiss that tranny good bye.
TT LSA/6L90e/9"
Old 02-06-2005, 11:44 PM   #15
browndawg71
1.48 sixty foots seems to be hooking pretty good to me!
Old 02-07-2005, 12:52 AM   #16
Purs
Got Big Block?
Purs's Avatar
hey browndawg, what are the specs and brand of the converter you run?
Old 02-07-2005, 01:19 AM   #17
FirstGen
Just Don't Stop!
FirstGen's Avatar
Really, 1.48 sixty foots huh. What are your 1/4 or 1/8 mile times? ET and MPH? How many times you taken it to the track? What is your race weight?
TT LSA/6L90e/9"
Old 02-07-2005, 02:36 PM   #18
browndawg71
purs i run a" off the shelf "tci . ran a b&m but it kept getting looser and looser. picked up about 6 mph when i changed.FirstGen, i probably have over 50 runs on this combo. weight is 3770 w/out me in it, im 260. best et 6.80 @ 101mph on 200shot (pump gas) and driven through the gate. ran it once at thunder valley in OK. 1/4 was motor pass 12.50@107 w/ slipping ass convertor. dont get to run 1/4 much as the nearest track is 2 hrs away.
Old 02-07-2005, 02:42 PM   #19
FirstGen
Just Don't Stop!
FirstGen's Avatar
Nice times. I was gonna say no way you could pull off 101 mph in the 1/8 with 480 rwhp at 4000 pounds. 6.80's are fast no doubt. I'm very surprized that you still have a tranny, maybe you got a freak th-350.
TT LSA/6L90e/9"
