Old 05-29-2002, 12:08 AM   #1
bad71gmc
stock decal removal
I know this is not related to 67-72 but you guys are so much more knowledgable that the other boards . Does anyone out there know of a quick and easy way to remove the ugly a$$ stock decals. My daily driver is a 1991 Chevy Suburban and I want to take off the stock decals and pinstripping on the side of it but the decals are a pain in the a$$ to get off and when I get them off the adhesive is even harder to get off. Any suggestions ????
Thanks a million guys !!!!!
bad71gmc is offline   Reply With Quote
Old 05-29-2002, 12:17 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
I've removed stock decals on several rigs and have had the best luck with a heat gun. If you take your time and go slow and steady, most of the adhesive should come of with the decal. With the remaining adheasive, I used 3M Adhesive remover. It's not a really harsh product so it's not as hard on the paint. You still need to be careful because it will remove paint if you are agressive with it. Hope this helps.................
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 05-29-2002, 12:26 AM   #3
bad71gmc
I used a heat gun but had the most trouble with the residual adhesive, I will give the 3m stuff a try. Thanks
Old 05-29-2002, 12:26 AM   #4
thood
thood's Avatar
3M makes a rubber wheel that you put in a dril and "erase the decals" it takes some time but works very well and will NOT hurt paint. you can get it at any paint store. good luck.
70 swb restored by myself and some help from this board!!
I hope to drive it some day!! portland OR
thood is offline   Reply With Quote
Old 05-29-2002, 07:30 AM   #5
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
whip out the ole lady's hair dryer and grab a bottle of lighter fluid for the glue or wd40 they both work really good
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 05-29-2002, 10:43 AM   #6
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
The 3M eraser wheel is the best and won't damage the paint. Definatly worth the 10-15$. Can do the whole truck in about 30min, including all the glue from those nasty side moldings.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 05-29-2002, 10:55 AM   #7
John Fabris
TOTY 2006
John Fabris's Avatar
The 3M rubber wheel is the best way to go!!!
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 05-29-2002, 11:41 PM   #8
bad71gmc
Smile
Thank guys for all the info. I went to the local NAPA store and ordered the 3M rubber wheel and will give it a try.
Thanks again everyone !!!!!!!!!!!!!!!!
Old 06-03-2002, 01:24 AM   #9
bad71gmc
I used the 3m stripe removal disc and it worked great, my hats off to the guy who invented it.
Thanks for the info guys
Old 06-03-2002, 02:15 AM   #10
thood
thood's Avatar
glad I could help out! (that does not happen often) haha
