![]() Join Date: Mar 2001
Need measurement, Engine to radiator w/long H2O pump
Can some one please tell me the clearance from the front pin sticking out of a LONG water pump to the radiator fins....on a 350SBC with the engine in the V8 position. Also, would like this measurement to a [2 or 3] core radiator, or at least tell me if you are measuring to a 4-core rad. THANKS!!!
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
![]() Join Date: Mar 2003
Bomba de Aqua? We kinda hit on this subject about 3 weeks ago. I don't think we came up with a measurement to the radiator though but If I remember right the difference is 1 1/8'' between the short and long pump. If you use big block towers it will set the engine assy back 1''. Don't know if that helps you at all.
Cantankerous Geezer
Have mine assembled now, so all I can give you is from the pulley that the fan mounts on to the 4 core radiator is 4". I have a 1" spacer with a flex fan on mine.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
From the front of the pulley to the fins I measure about 5.5 inches. I have a 3 core radiator, 350 with a long water pump mounted in the V8 position... And from the rad to the fan clutch is about 1 to 1.5 inches.
78 C10 LWB Super Cheyenne |
thanks, sounds like what I need to know, at least for the moment...
#6 | |
Bloo
ill measure on my 69 and the 71 c10 tomarow to get you some more measurements to know an average... my 69s engine *appears* to sit back further then the 71 c10, but both of them are on stock sbc towers
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
