New Guy, New Truck, Old Questions
Hey guys whats up. First thing, I think this forum is absolutely awesome. I just bought the first COOL truck that I've ever had the chance to own. I have lots of questions but I'll just start with the important ones.
![]() --First off I just purchased a 71 c20 for $700! Its got a 350 with a 4spd. It's 3/4 ton and has 4x4 with a posi rearend. The first thing that I want to ask is prob. the most important. The truck runs great and all but the brakes are really shotty. ![]() -How many of you have gone HEI? Is it worth it? -How many of you have headers? I need to redo the exhaust and just thought that It would be easiest to throw some on when I redo the exhaust. How much difference will a good set make and what are some of the best makes? -My heat doesnt work and being I'm in MN, this is gonna be a problem. Where should I start to find out why it doesnt work? -Lastely, I'm going to dig into the lighting this next weekend and I read in a prior post that a toggle switch is a good upgrade to the headlights. Ya or na? Oh one more thing. Has anyone added power steering to their truck? Is this possible and if so what all would be involved with that? It's cool that there is a forum out there for us guys and want to say that I think I'm gonna make myself comfy here a lot. If that's ok with all of you ![]() Oh here's a pic. I hope this works! |
#2 | |||||||
![]() Quote:
Good looking truck, gonna put the standard bed on it or leave the flat bed on it?
71 Chevy C10 "The Rust Bucket" 72 Chevy C10 apart in the garage 02 WS6 T/A Fast Black and bad@$$ 93 Nissan Pathfinder "Emily" Totaled RIP girl ![]() 05 Jeep Grand Cherokee-HEMI powered ![]() 87 Iroc Z28 305 TPI auto (crying out for an LS1 swap) |
Are we there yet?
Good find and a great deal at that. Welcome to the boards. As far as your questions go:
1. Can't help you. I still have the 4-wheel drums. 2. Do the HEI conversion, unless you like adjusting points every weekend. 3. If your re-doing the exhaust system you might as well get the performance gains of the header while you are at it. 4. Check your water level, if there isn't any water in the radiator there will be nothing to flow through the heater core. A lot of times if a heater core goes out, it will leak into the floorboard. When this happens most of us poor people will just by-pass the heater core until we can afford a new one. Check to see if someone has by-passed yours. You will know because the hoses coming out of the passenger side of the firewall will just be connected to each other and not go to the engine. After that, I would check the blower motor. 5. Haven't gone there yet. 6. Still no power steering either. Hope I helped. Ron |
Welvome to the board i dont think anyone minds you comin here.
Dan. 55 F100 panel truck project 64 ![]() 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 ![]() 83 ![]() 88 ![]() ![]() 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops ![]() ![]() ![]() ![]() ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Welcome! Since your questions have pretty much been addressed, lemme just add a bit to your heater problem. I'm assuming the fan (blower) motor works, but just no heat coming out? Long shot, the squirrel cage fan could actually be missing... Or maybe the vent doors aren't in the right position to direct the heated air... More likely, a water circulation problem. Some models (with A/C, I think) have a vacuum-operated water valve on the pass. side inner fender - it may be bad. With the engine warmed up, check all the heater and radiator hoses to see which are warm or hot, and go from there.
Got Light Emitting Diode?
welcome to the board from portland or. i did power steering on my truck (1/2 ton 2wd) all boxes are the same from 69-87, except for a change to metric fittings in the 80's, but those can be changed. i'd imagine that its the same for a 3/4 ton 4wd, just pull what you need off of a truck with your same running gear. as far as your other questions check out the FAQ sections. there is alot of useful info on there (sorry Krue, beat you too it
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Thanks for all the help guys. And also to bombard you with questions so badly. About the heater, I can barely get the levers in the dash to move much less get any air out of the vents. The truck only sat for two years and the PO started it at least once a week. So he said. I'll start with the ccolant and hoses and work from there. Actually maybe I'll just change all the fluids tomorrow. Can't hurt right?
if your levers are hard to move the cables need lubed and it could have just came off of the deflector to allow heat in the cab
Welcome. The heater valve on non-A/C systems can also freeze in one position, such a off.
I think you have a K20. K=4wd, C=2wd. I'm a little surprised you don't have pwr steering in a '71. Perhaps a work truck thing. And I agree with doing the brakes yourself. First timers just need a little help on a few finer points. The rest is easy–and cheaper.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
Yeah I've got a buddy that has a 68 and his has power steering. I couldn't believe that it didnt have it either, but...for now I'm just gonna get a smaller thicker wheel for it. Build my forearms that way
I had a 71 GMC 4X4 3/4 ton that came without power steering, a crashed '71 Chevy 2WD 1/2 ton (that I just freshly totalled) and an incomplete 67-72 Blazer. Between the 3 vehicles I had enough parts/belts and pulleys to put the power steering on the 3/4 ton 4X4.
I do remember using the pump off the crashed truck, the steering box off the Blazer and the steering arm off the 3/4 ton 4X4. I think the splines from the 2WD and the Blazer are different.....anyway, it worked.
Martin Gibson
USAF Retired 1964(-ish) C10 |
Designated A-hole!
Welcome to the board from South Mississippi! As has already been mentioned there's a lot of good info here.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#13 |
Who me?
Welcome, and what a score!
Living the dream ![]() 72 2WD Blazer, under going porter built surgery 67 GT Mustang fastback 67 Mustang coupe C/S clone 64 Falcon sprint hardtop |
#14 |
Active Member
Where in MN are you?? I'm just south of the cities in New Market. If your close I could probably help you out. BTW nice score on the truck.
Later, Paul
'67 Chevy LWB (Running) '67 Chevy LWB (Not Running) '70 Chevy LWB (In Pieces) '72 Chevy LWB (In Pieces) |
#15 |
Welcome to the board. I am in East Central SD.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#16 |
Paul, I'm just south of Mankato. I'll email ya.
Just got back from the store! |
#17 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
![]() Welcome
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#18 |
I actually looked at wheels today and I decided against buying one. I came to the realization that it must have a big wheel for a reason. I dont know why that didnt click in my head at first.???????
#19 |
Holler if you ever need any parts, I am just a few hours West of you.
Shawn
#20 | |
#21 |
I was wondering if anybody would notice that! I knew one of you would.
-Cory |
#22 |
Andy (longhorn Man) would have, there is a picture on here somewhere that the whole back of his car is filled with empty DEW cans.
#23 |
Welcome from SW Washington State....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
