Old 02-07-2005, 03:59 PM   #1
Deuce
Deuce's Avatar
Drum to Disc Conversion.
What parts do I need to convert a 67 Chev with drum brakes to either 71/72 discs OR 73+ discs and spindles.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 02-07-2005, 05:00 PM   #2
krue
Designated A-hole!
krue's Avatar
The easiest way is to swap the entire front crossmember out of the donor vehicle. Get the booster, master cylinder and prop valve off of a 71-72.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-07-2005, 05:37 PM   #3
Deuce
Deuce's Avatar
I was just told the lower balljoint and outer tie-rod end are the only things that need to be changed other than the MC/Prop valve. Is this true??
Old 02-07-2005, 05:41 PM   #4
raggedjim
raggedjim's Avatar
I don't think the outer tierod end from a 71-72 will fit the sleeve on a 67-68 (different thread), you might need the whole center link from a 71 up.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 02-07-2005, 05:45 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
I'm not sure, but other than swapping the spindles, rotors, and associated brake parts I think that's correct...something about the tie rod connection with steering box being different. I thought the lower ball joints were the same???....I'm sure others will jump in too... I swapped my whole set-up. I paid, I think, $125 for complete disk set-up off of a 72 with the power MS and P-valve. I've read several posts where people had trouble getting rid of a disk set-up. Post a WTB on parts board and see what you can get.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-07-2005, 07:48 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Lower ball joints changed when they went to discs in 71. The same lower fits the newer 73-87 style trucks too.
Old 02-07-2005, 07:55 PM   #7
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
there are adapter sleeves out there to make the tie rod conversion if you dont change your drag link
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-07-2005, 07:59 PM   #8
tmad
I bought the entire conversion kit! cost me about 900.00 total but it bolted right in!! New spindles,rotors calipers ,pads vac. drum,prop valve the works! Took very little time and although its a good sum of money we are talking brakes here,hard to stop without them!!!
tmad is offline   Reply With Quote
