ZOIE AND ZACK
Gas Tanks
What Are You Guys Using For Gas Tanks Original Or Aftermarket. The One On My 67 Is All Rusted Out Inside And I Need A New One Trying To Get Ideas On What To Use. What Is Price Difference In Orig. And Aftermarket What Is Easier To Install.
AMERICAN BULLDOGS AND CHEVY TRUCKS 71 1/2 SUBURBAN 402BB IN PROGRESS 90 1/2 TON SILVERADO 02 1/2 SUBURBAN 67 GMC 1/2 TON LONGBED 05 AVALANCHE |
under bed or in cab? you can usally find a good in cab one for sale pretty resonable
Dan. 55 F100 panel truck project 64 ![]() 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 ![]() 83 ![]() 88 ![]() ![]() 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops ![]() ![]() ![]() ![]() ![]() |
ZOIE AND ZACK
Ttt
More Cowbell....
Let's review.....Under the bed (blazer tank) or in the cab behind the seat??? Which are you talking about?
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
67 is sold
If it is your '67 Longbed and you still have the incab tank, they are readily availble used for $25-$30 or so in great condition, especially in Texas.
Hell, I have 2 like new tanks in my garage ![]() |
#6 | |
#7 | |
Vortec in the works
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
ZOIE AND ZACK
Got A Call Into Local Yard Their Looking For One For Me. Would Like To Relocate To Under Bed But Right Now Looking For A Good Used No Rust Behind Seat Tank.
http://store.summitracing.com/defaul...4839036+305650
For about $250 Tank, brackets from summit, 13 ft of 3/8 fuel line, 1 cap for the second fuel outlet on tank, 1 90 degree fitting, 1 piano hinge, 4 hours of labor I relocated my tank fairly cheap and easy. The tank comes with a gm sender. A little cutting here and there and it bolted up great. I made a small square cut in the bottom of the bed, welded a piano hinge to each side and couple tabs around the corners for little extra support and my filler compartment was complete.
1969 Chevy C-10 Custom 358/400 on 20's 1967 Chevy Chevelle SS 468/400 on 17's |
