paint?
so wich paint brand is the best for your money? and qaulity? and all of the pros and cons to them?
Dan. 55 F100 panel truck project 64 ![]() 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 ![]() 83 ![]() 88 ![]() ![]() 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops ![]() ![]() ![]() ![]() ![]() |
![]() Join Date: Nov 2004
I used acrylic on my 86 toyota and it looked really good and was really easy to paint, becuase you mix all the stuff up and spray it at once as opposed to spraying on base, then clear, and it was cheap....I think $80 for 1 gal paint, pint of reducer, and the little jar of hardener. BUT BUT BUT it chips easily. Could be bcause I used cheap primer. When I do my 67 I'm gonna try base/clear which is much more expensive, but, imo, is a million times better. That's the extent of my knowlegde. You probably want to know about base/clear.......
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
i really dont want anything to chip easy cause it is gonna be on a truck i really would like to know about all paints how to mix wich is the best mixture what you need to paint with etc.
If you're going to paint over the existing paint job, you'll need some prep-sol to remove any wax or grease, 1 gallon of sealer, 1 gallon of paint, a pint of activator, 1 gallon of reducer, 1 gallon of clear and that should do it (I think).....It's been about six years since I painted my last car.
no its been sanded down and got some primer on it,right now i am in the process os the patch panles and stuff
but that should come in handy when i do my moms truck..........what i'm wanting to know is who makes the best paint like what brand is the best along with primer etc
Dupont makes a good Epoxy primer (DP-90) but it costs $$$. If you didn't use Epoxy primer on your truck, you'll still need a gallon of primer sealer. I always use Dupont Chroma-base.
A good cheap paint that I like is Nason it is made by Dupont.
Nason will also dry fairly quick too. I've used it several times with nice results.
so nason will do fine? do i need a primer on it before i paint? i have only been useing rust oleom primer on it?? i'm DUMB when it comes to paint so i'm tryiin to find out about it.
I would apply a few coats of primer on any body work block it. Then apply two or three coats of primer over the whole truck the block the whole truck. But first you need to remove that spray can primer (sand it off or wipe it off with laquer thinner). The quality of your finnish is only as good as what is underneath it
what do you mean block it?
#13 |
block sanding it
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
#14 | |
huh ???
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#15 |
Custom Truck, here I come
I just painted the cab of my truck with PPG and I'm very pleased with the paint.
23$ / L so that is 87$ / gallon. |
#16 | |
http://67-72chevytrucks.com/vboard/s....php3?t=138647 |
