theft detterant idea...
would this work? take a inline blade fuse holder....put it in your HEI wire. blow up a blade fuse and when you are gonna have your truck parked a while put the blown fuse in. it would look perfectly normal unless someone takes fuses out to check them before stealing your truck lol...
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
Member since 2000
or they can jam a small screw driver in place of the fuse to drive the current.
well but i mean what thief is gonna get in your truck be like....hmm that's a fuse holder better check that out lol
Member since 2000
You'd be amazed how smart some car thiefs are........a good thief would just tow your truck away. I say it's a shot but why not run a switch instead?
well i thought if they find the switch they would know what it is...they see a fuse down under the dash nothing would look out of place....
I think the fuse idea is a good one but I've seen a push button switch behind the cig lighter. When you push it in the truck won't start. Thats ok unless the thief smokes and tries to use it.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
Professional Grade
What I planned to go was set up a "kill" switch under the dash (just on the upper lip of the bottom of the dash on the inside) that sets off a home made alarm system if it is hit
![]() Bascially, I'm gonna find a relay that turns on and stays on when the switch on the inside is flicked on, even if you flick the switch off again, or cut the wire. Set this up so it provides power to the horns through a momentary flasher like a signal light flasher. Then, to turn it off, have another switch inside of the engine compartment somewhere that you flick to set the relay to the off position ![]() ![]() Then, have the real kill switch somewhere like behind the seat or something :p Some theif comes in, cranks the truck, won't start, looks for a kill switch, hits it, and the truck starts honking and doesn't stop, even after he turns the switch back off, or cuts the wires to it :p And yeah, the horns on my truck arn't exactly quiet, lol Biggest issue would be with how a guy could set up the horns so he cannot simply cut the wire to the horn... Prehaps a guy can extend the horn wiring and run it through the core support / fenders so it is not easily accessed ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Your UncleBen
![]() Join Date: Dec 2002
I am going to charge up the digi-cam and take some pics of what the PO (my cousin) did to the 72 C-10 that I just bought off of him....Glad he told me about them
![]() I will get some pics. lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
I just (tonight) installed a dummy flashing LED light under the ignition switch (to the left) in an exsisting hole I had previously drilled. I installed a 330 ohm resistor inline on the + side of it and wired that into the cig lighter spade on the fusebox, and ran a temp aligator clip to bare metal on the other. It works very good (nice and bright) however I would like to change the location of it somewhere higher & more visable. I'm still going to wire the - side of the LED into my ignition switch so it shuts off (when key is switched on) but I'm not sure which wire to tap into. Anyone know which wire to use? And sorry for stealing your thread 67Chevy. Doug
oh it's no idea...im just looking for some cheap easy ideas...
#11 | ||
Majician
#12 | |
Your UncleBen
![]() lata CHRIS
#13 | |
One night some theives were working my parents alley. They got into his van first. The horn started "blinking". When we went out to check it out there were tools on the roofs of two other neighbor's cars. That wasn't the only time his $10 worth of parts saved stuff. Heck it probably only cost him $5 back then.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#14 |
Theft Deterent
I think as far as a 'switching' system goes, there's two good option's.
The power wire to the HEI would be easy and effective but the other good one would be an inline switch on the starter selonoid wire from the key. No spark, no start. No crank, no start. Course the towing thing memtioned above would overcome most 'deterent' systems anyway. Last edited by vtblazer; 02-08-2005 at 09:20 AM. |
