![]() Join Date: Aug 2002
need some feedback
Im looking at getting the suspension going on my truck. I like the Rancho system. Any ideas as to what would be a good set up? Its going on a 82 1/2ton 4x4 short box. I would like to get the dual shock set up and the steering Stabilizers but not sure if they will work on my truck. Any help would be great. http://www.gorancho.com/Flash_gorancho_main_new.htm
Thanks Jason |
huh ???
I had a blazer with a Rancho lift on it and hated it. I also had a bronco with a skyjacker lift and loved that. The Rancho was stiff and bouncy, the skyjacker kit rode like a caddy even with 39's on the truck...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Do you have a website of any info on the skyjacker?
I have a Rough Country on my 85 and I like it alot. It does ride a little rough but not to bad. It comes with everything needed to do a lift. I like it so much I just ordered a nother on for my 83. They only run 425.00 for a 6 inch.
Chuck '85 Chevy Silverado 4X4 ![]() '91 Chevy 4X4 Suburban ![]() http://www.cardomain.com/memberpage/545941 |
huh ???
For those of you who had a nice ride, how did it preform?
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
huh ???
I wheeled the cr@p out of the bronco and never had a problem. The lift was a 6" skyjacker and a 3" body to fit 39" swampers. I even had the truck off the ground a time or 2. If I ever lift a truck again I won't think twice about going with Skyjacker, and I'll never go with Rancho again...
Chuck
Ok next question. Would it be a good idea to put all new shocks on NOW while i have the box and front end off it? Or wait till im done? I really dont have the clearance in my garage to fit the truck once it has been lifted but i would like to get the shocks on at least.
huh ???
I'd wait until after the lift is installed...
Chuck
if you are doing a suspension lift, you will have to have most all of it off anyways, so putting shocks on it then wont be a problem.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Narcissistic Prick
In case it still matters, I'm running a 4" superlift kit with adj. rancho shocks (2 in front, 1 in the rear) and it rides great. No nasty sagging either.
-Shawn |
