Old 02-08-2005, 12:02 AM   #1
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
i need u-bolts
i need some ubolts that are 15" long or longer to fit around a 3.25" axle
i measure them by putting the treaded end on a counter top then measure to the top of the u
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 02-08-2005, 12:11 AM   #2
1FaastC10
1FaastC10's Avatar
15" long? how big of a block are you using?
1FaastC10 is offline   Reply With Quote
Old 02-08-2005, 04:54 AM   #3
1972
Majician
1972's Avatar
Stacking two 6" blocks? I don't know, but a 15" ubolt sounds scary!
1972 is offline   Reply With Quote
Old 02-08-2005, 07:19 AM   #4
LONGHAIR
4" of spring thickness
4" for axle and pad
6" block
1" minimum for the nut
15 inches does not sound so bad, though I'm not a huge fan of 6" blocks.
Try a local spring shop (big trucks like dump trucks) they can custom make nearly anything. They won't be cheap though, as much as double the cost of the ones you get in "block kits" in catalogs.
LONGHAIR is offline   Reply With Quote
Old 02-08-2005, 11:23 AM   #5
chipotledude05
Strategery
Check out Carrier Spring. They're pretty cheap and they custom make everything to your specs from military grade stuff.
1961 Chevrolet Apache 1/2 Ton SWB 4x4
chipotledude05 is offline   Reply With Quote
Old 02-08-2005, 10:00 PM   #6
69gmcfleet
I got mine made at a big rig truck parts store. They made them right in front of me to my specs.
Jeff
'69 GMC K2500 LWB, '74 350/SM465/Rockwell T-221, cnD44/ffD60, 3.73 gears, 31" BFG's
(originally had 305ci V-6)
'05 VW golf
'84 HD Sportster XLX
'68 GMC K2500 parts beast
69gmcfleet is offline   Reply With Quote
Old 02-08-2005, 10:34 PM   #7
cochino12
It followed me home?
cochino12's Avatar
I have a set I was going to use on my 14bolt w/4" blocks. $25 + mail
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-08-2005, 11:12 PM   #8
charlieo
"U" Bolts
Get your own U bolts can't have mine ! LOL Sorry had to do it .
charlieo is offline   Reply With Quote
Old 02-09-2005, 01:16 AM   #9
1FaastC10
1FaastC10's Avatar
6" block?! someone doesnt like his rear springs!
Old 02-10-2005, 09:56 PM   #10
sixty8c10
sixty8c10's Avatar
thanx for the replies guys i already ordered some from the link that chipotledude05 posted
