02-08-2005, 03:38 AM | #1 |
BLAZERHOLIC
difference between c10, c20, c30 frames
I heard the 4x4 k10s and k20s were the same but just had different axles. So I was thinkin what is the diffrence between the c10-c30 frames cause me and my uncle want to build a drw c30. We were gonna get a c-10 or c-20 longbed and put a 73-87 drw 3500 front crossmember and rear axle with some modified stepside fenders. Do the c-30s have the trailing arm rear suspension cause we wanted to bag it but not make it lay frame, and having the trailing arms would make it a lot easier.
02-08-2005, 05:59 AM | #2 |
its all about the +6 inches
The one ton chassis never came with coils, so it'll only have the big 'ole leaf springs, they are also longer, 133 inch WB or 157. The frame is notably thicker and has more reenforcment.
02-08-2005, 09:57 AM | #3 |
Watch out for your cornhole !
You can build a dually out of a c-20 coil spring truck really easy if you wanted to. I have pics of one by my house here that is done that way. It's a real neat truck.
02-08-2005, 08:38 PM | #4 |
I have a radical idea!
So is it true that the 1/2 ton and 3/4 frames are the same? I have a 1 ton and 1/2 and the difference is obvious. Howver, I do not have a 3/4 nearby (that I know of) that I can compare. Can any body confirm it either way? Thanks!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-08-2005, 09:00 PM | #5 |
TX just posted some pics showing the difference between 1/2 and 3/4 ton frames a while back. Read this thread here:
http://67-72chevytrucks.com/vboard/s...=frame+doubler
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
02-08-2005, 09:57 PM | #6 |
The old tale that 1/2 and 3/4 ton frames are the same cost me some money and time. That's the reason I have an extra frame is because someone told me they were exactly the same. Once I got them next to each other and began to swap parts, I found out differently.
That's why I was so quick to jump on that other thread that Robert quoted, and post pictures, to hopefully debunk the myth and save someone else the hassle I went through.
02-08-2005, 11:22 PM | #7 |
Tx, Great info. The frame I have is a '70 GMC LWB C1500 with leaf springs. From what I can gather from the other post, the extra bracing and doubling was done on 3/4 ton trucks w/ coil springs. I guess that means that the 3/4 T and 1/2 T with leaf springs are pretty similiar, right??
02-09-2005, 11:11 AM | #8 |
bump
02-09-2005, 11:27 AM | #9 |
The frame on the C30 is bigger, the channel under the cab is deeper, its like 7inches where the C10 is like 4-5. But the back where the springs are is the same as the C10, the C30 tapers down.
02-09-2005, 10:36 PM | #10 |
it tapers down, but it is still thicker metal on the one ton frame.
12-27-2019, 03:25 AM | #11 |
Re: difference between c10, c20, c30 frames
Digging up a damn near 15 years old thread....
Do the frame differences extend to the 73-87 (91) C30/R30?
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
12-27-2019, 08:10 AM | #12 |
SWB 4x4 Collector
Ford Assassin, yes the 73-91 Square body frames have thier differences as well.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
