02-08-2005, 02:10 PM | #1 |
Question on angle plugs
I have a 1974 400 small block destoked to a 377. It has performer rpm straight plug heads. Im planning to buy some victor jr. heads which are angle plug. What is the difference and will angle plug fit on my block.
1969 c10 2wd 377 destroked 500hp - In Planning stages of a 700hp 8-71 blown 406 sb 1990 ranger 2.3L 250k and counting I want my truck to have enough power that im afraid to put it to the floor |
02-08-2005, 02:48 PM | #2 |
Mike
What they might not fit is Your exhaust,cast or headers.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
02-08-2005, 03:16 PM | #3 |
Weekend Warrior
running headers or cast manifolds? - i would hope headers with that HP level
You might have a tough time finding headers to fit. they make them for '67-'69 Camaros i think - supercomps you might have to have some made depending on your application. regualr headers might work..but you will have to "dent" a few primaries to get the plugs in...and then the wire boots might be too close (burn) use "shorter" "header plugs" to gain a little clearance i had a set of original casting angle plug heads and nothing fit well but a set of RamHorns.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
02-08-2005, 03:47 PM | #4 |
i have headers but i hope that i can find something can can fit i really like those victor jr. heads. Thanks for the info.
02-08-2005, 08:15 PM | #5 |
Hooker super comps work with angle plug heads. I have a 1 year old set 1 5/8x 2 1/2 I just took off my truck...200 plus the ride
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
02-09-2005, 01:56 PM | #6 |
Thanks for the info but i saw on their website and i need the 1 3/4 x 3 plus itll be a while before i can get new heads dont have enough $$$$$$$$$$$
