Old 02-08-2005, 02:48 PM   #1
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
fabbed up some front sway bar mounts.(PIC'S)
I spent the last few days fabbing up some front sway bar mounts for my 71 Blazer.
As some know our 4x4 Blazers and 4x4 trucks did not come with a front sway bar.
A front sway bar from a late 70's-80's Blazer can be used.Just find the doner truck and take the bar,mounting bushings and the spring plates(they are a direct bolt on.)
Here's the spring plates
After making some templates out of cardboard I started fabbing up the mounts.
I used 2x4 box tube .120 wall thickness.I also used 1/4" flat stock in places as well.
After the initial cuts I marked where the sway bar would bolt to the mount.
I then welded in two nuts on the inside of the boxed tube.
After a little more cuttiing and rough fitting of the pieces,I tack welded the pieces together and made a final test fit.
Once I was satisfied with the fit I welded up all the seams and ground my welds smooth.
I repeated the process for the other mount.
After these pic's were taken I ended up welding nuts to the mounts and painted the mounts black.
Here's how it all turned out.
In these pic's I didn't have the mounts permanently fastened yet.But they ARE in their final position.
Here's the beefy sway bar.
ALL the pic's I took while making these mounts can be seen HERE
I'll give Steve Chin credit as I based my mounts on his basic design.I just modified the design slightly and beefed them up a little.
I welcome any comments,questions or critiques.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-08-2005, 03:11 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
As always
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-08-2005, 04:23 PM   #3
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
AWESOME! Not only helps side to side sway, but helps keep the axle located. So, saying that you had the time and motivation, how much would you make another set of mounts for?
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 02-08-2005, 04:56 PM   #4
BobbyK
BobbyK's Avatar
Well...everyones truck is different and the pair I made may not fit YOUR truck EXACTLY.
The pair I made invovled ALOT of trial fits,cuts,fit again,etc.
I made outlines of all the different pieces I cut.
If enough people want the plans I'll see if I can figure out how to attach a PDF so anyone who wants the plans can just down load them.(plans would be actual size)
Just remember the outlines I made still needed alot of fitting.But at least it get's you in the ballpark!
Old 02-08-2005, 05:32 PM   #5
redz 1970 K5
OBS guy
I want bolt on and I want it yesterday!
Besides, I've bolted on enough aftermarket 'bolt on' swaybars and performance products to know that stuff never fits right. Your quality standards are too high. One size fits all! Write Hotchkis on the box and ship it!! (j/k)
Well, I guess since I would need it dropped to work with my lift, I will have to make it myself...
Good work! Obviously a quality craftsman!
88 Suburban
Old 02-08-2005, 06:10 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SWEEEEEEEEEEEEEEEEEEEET
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-08-2005, 06:29 PM   #7
71RestoRod
71RestoRod's Avatar
Nice work, BobbyK!
One thought... do you have enough room with your lift to use disconnects? When I fabbed my mounts I was concerned about the geometry being off and the possibility of the swaybar binding up, putting a lot of undue stress on the front crossmember. The disconnects alleviated that concern, but I think you might need a lift in order to use them.
It's neat to see a different approach to solving the same problem. Your mounts look similar to the one's I fabbed for mine, but I didn't box the square tube in front. The tube shape came out almost identical!
Did you ever see the mounts that Steve Chin made? That's where I originally got the idea for the conversion. Rather than welding flanges on the sides though, I used the (large) existing holes in the crossmember as fastening locations.
Here are a couple of pics and a link to the details... more ideas for those interested in doing this conversion. (not to steal from Bob's post just trying to contribute w/ ideas and discussion):
Building Swaybar Mounts
71RestoRod is offline   Reply With Quote
Old 02-08-2005, 06:37 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very nice one more thing to add to my list of fab work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-08-2005, 07:12 PM   #9
71jimmy
71jimmy's Avatar
Great job!! One more thing for my list too.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 02-08-2005, 10:26 PM   #10
BobbyK
BobbyK's Avatar
Resto,Ya I've seen Steve Chin's mount's,that's where I got the idea.I should add that to my write-up.
I like your mounts too.Much simpler design than mine.I was trying to keep the mounting points parallel to the ground,that's the reason for the notches.
I have no lift,stock suspension,just 33" tires.The sway bar is parallel to the ground.
It's my understanding that they should be as parallel to the ground as possible
Old 02-09-2005, 12:06 AM   #11
orangeuavol
GO VOLS!
orangeuavol's Avatar
I'll be making my own mounts as well. Hope you guys haven't filled a patent yet Great job and thanks for the ideas.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 02-10-2005, 03:02 PM   #12
BobbyK
BobbyK's Avatar
I reinstalled the sway bar yesterday and took a drive.
It REALLY tightend up the handleing.It feels like you get "pulled" through corners now
I also cleaned up the sway bar.Took about 6 hrs of sanding and polishing but I now have "blingin" front sway bar.
I clearc oated it and reinstalled the urethane bushings.Turned out o.k.
Here it is before
And here it is after.
Old 02-10-2005, 10:24 PM   #13
71jimmy
71jimmy's Avatar
Sweet!
Old 02-12-2005, 07:51 AM   #14
crispy
'71 Chevy Blazer
great job BobbyK. as always, i am completely impressed by your craftsmanship and attention to detail. i've been all through your website with all the pics of your blazer and it's given me lots of ideas. keep up the good work
'71 K5 Blazer (new project / daily driver)
"If you are not working to improve the situation, you have no business complaining"
crispy is offline   Reply With Quote
Old 02-12-2005, 03:01 PM   #15
skid
Very nice work! This is something I definately want to do, after I get the new motor with TPI installed.
I had a 4 inch lift on a 77 Blazer, but don't remember if the sway bar remained relatively level or not. It did seem to handle better with the lift though, probably as the result of new springs, shocks and tires.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 02-13-2005, 05:13 AM   #16
donkey69
JB-80 &amp;quot;Twice as Good&amp;quot;
donkey69's Avatar
Thats one serious polish job......really looks good!!
HEY NOW!
donkey69 is offline   Reply With Quote
Old 02-13-2005, 12:36 PM   #17
obsesive23
Who me?
obsesive23's Avatar
Great job! I think you need to start selling your guys stuff it looks top notch to me!
Living the dream
72 2WD Blazer, under going porter built surgery
67 GT Mustang fastback
67 Mustang coupe C/S clone
64 Falcon sprint hardtop
obsesive23 is offline   Reply With Quote
